Author Topic: RNS510 screen help  (Read 816 times)
Offline magicgilbert
RNS510 screen help
« on: July 14, 2013, 07:53:06 pm »
my rns510 as started to bubble away in the top left hand corner, as if its got a plastic cover over it, is this the case or is it something more? it doesn't seem to have anything to pull it away and don't want to mess to much incase I make it worse.
thanks
Torando Red ED30 num:1913 with stage 1 @ 296bhp
Re: RNS510 screen help
« Reply #1 on: July 14, 2013, 08:02:45 pm »
If not the first owner of this unit, could it have a screen protector??
« Reply #2 on: July 14, 2013, 09:10:03 pm »
not a clue, seems strange, should it just be the glass or is there some sort of plastic coating over them :-/
Offline jbc
« Reply #3 on: July 15, 2013, 08:34:05 pm »
If it isn't a screen protector then it might be the touchscreen surface that's lifted. The RNS has an old style touchscreen where you can feel it depress slightly when you touch the surface, not like a modern touchscreen on smartphones, etc which are a glass surface. If its this touch surface that's lifting then I'd be very careful as you might do more damage.
2012 Mk6 GTD. Tornado Red. TPMS, RNS510 and reverse camera retrofit.
« Reply #4 on: July 15, 2013, 10:44:46 pm »
thanks for the advise, didn't seem as it would come off, just hope it doesn't spread :-/
