Author Topic: Today I have mostly been..........Fitting an ITG CAI  (Read 66990 times)
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Today I have mostly been..........Fitting an ITG CAI
« Reply #105 on: September 08, 2009, 10:28:11 pm »
great info steve  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #106 on: September 08, 2009, 10:36:11 pm »
Re - DomT's question.
Previously I saw peak airflow readings @ WOT in 3rd of 246g/s with the stock airbox and pipercross panel.
With the ITG and revised Revo settings (B8-T5-F6) I have on a couple of occasions seen low to mid 260's g/s, today with the ambient of 26.5c this was down to 257g/s peak @ WOT.
HTH  :happy2:
« Reply #107 on: September 08, 2009, 11:00:49 pm »
Why such a rich fuel value?
Did you log your lambda with that setting?
Offline KRL
  • -Receive: 29
« Reply #108 on: September 08, 2009, 11:03:59 pm »
Maybe he has a HPFP?
Offline RobH
  • Revo stg 2+
« Reply #109 on: September 08, 2009, 11:04:42 pm »
i thought fuel 6 was the standard revo setting on stage 2+.
« Reply #110 on: September 09, 2009, 09:22:14 am »
I don't know with the k04 set up but with the k03's the revo recommended setting is F9.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #111 on: September 09, 2009, 09:23:35 am »
^^^ This was the recommended setting after Carl did some logging on my car a few weeks ago  :happy2:
« Reply #112 on: September 09, 2009, 09:49:50 am »
Interesting as that setting was also used on Gaz's S3 at vortex...
« Reply #113 on: September 09, 2009, 12:01:09 pm »
JKM set my Revo settings up when I had my HPFP fitted and after a few dyno runs of logging AFR found that a setting of 6 for fuel ensured optimum AFR on the car.
....Although my GTI is a K03 Revo2 (not 2+) and on stock FP, the AFR is important and JKM adjusted my setting to F7.
Each car is slightly different and we each have very differing combinations of mods.
Offline gazbutS3
« Reply #114 on: September 09, 2009, 12:18:05 pm »
you don't forget much do you bacillus  :congrats:
« Last Edit: September 09, 2009, 12:19:39 pm by gazbutS3 »
Offline robern2
« Reply #115 on: September 09, 2009, 01:09:07 pm »
Interesting comments about the fuel settings recommended.
My edition 30 is stage 2 (soon to be stage2+), currently its set to f9 as I was told this keeps things nice and cool.
Offline KRL
  • -Receive: 29
« Reply #116 on: September 09, 2009, 01:18:08 pm »
Having a fuel setting of 9 actually does exactly the opposite, it heats things up!
A fuel setting of 9 means you will be running a leaner AFR which in turn means your EGTs (Exhaust Gas Temperature) are going to be higher.
When you are running pump sw (stage 2+) it gives you the ability to run a slightly richer AFR because the upgraded fuel pump can run at a higher rail pressure up to 130.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #117 on: September 09, 2009, 10:07:03 pm »
Not sure if these will work but here are a couple of sound clips  :smiley:
Clip 1
Clip 2
Should give you an idea of some of the noises it makes  :party: :party:
EDIT - Don't click these links if you are incapable of using a computer, they are in m4a format (taken from the voice recorder on my iPhone), so will try to open in iTunes
« Last Edit: September 10, 2009, 07:46:29 am by SteveP »
Offline cmdrfire
    • Commander Fire - my blog
« Reply #118 on: September 09, 2009, 10:17:04 pm »
Steve, no joke, when will these be available and when can I buy one?
oldtomo
« Reply #119 on: September 09, 2009, 10:19:02 pm »
Sounds incredible  :happy2:
