Author Topic: Today I have mostly been..........Fitting an ITG CAI  (Read 67002 times)
Offline cmdrfire
    • Commander Fire - my blog
Re: Today I have mostly been..........Fitting an ITG CAI
« Reply #90 on: September 05, 2009, 08:35:23 pm »
Cool, because I urgently need one as a replacement and I <3 ITG.
How do I get on the preorder list because I really need one as soon as they are released...
« Reply #91 on: September 05, 2009, 09:04:47 pm »
Do we know a price yet? Or even a ballpark figure?
:smiley:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #92 on: September 05, 2009, 09:06:56 pm »
^^^ It's going to be a very similar price to the forge  :smiley:
« Reply #93 on: September 05, 2009, 09:10:32 pm »
....Around £300 then. :drinking: Cheers, Steve.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #94 on: September 08, 2009, 08:53:51 pm »
Ok, I logged blocks 31 and 32 as suggested in the other thread.
Lambda (Partial) - Self-Adaptation = 2.3%
Lambda (Idle) - Self-Adaptation = - 0.7 %
As for the "Lambda Sensor - Current Value" vs. "Lambda Sensor - Specified Value" this typically was within +/- 0.05 at most of the specified value expect when lifting off the throttle.
Hopefully this will mean something to the techies that have been requesting this  :happy2:
Offline Poppa Dom
« Reply #95 on: September 08, 2009, 09:00:40 pm »
Out of curiousity Steve, what was the maximum Mass Air Flow (g/s) that you have logged? Not sure if you have this info from current logs?
Offline robern2
« Reply #96 on: September 08, 2009, 09:06:28 pm »
So the ITG is somewhat 'sucky' in terms of noise, how does the forge compare, presumably its quieter ?
Offline Janner_Sy
  • -Receive: 113
« Reply #97 on: September 08, 2009, 09:36:37 pm »
id presume the forge to be quiter as well as the filters are enclosed
Offline cmdrfire
« Reply #98 on: September 08, 2009, 09:43:06 pm »
Any idea of a release date? I'm still after one quite urgently and if it's prone to be more like four weeks rather than (say) two I think I shall be forced to get the EVOMs (which would be sad, as I <3 ITG).
Offline jonnyc
  • Herrooooo!
« Reply #99 on: September 08, 2009, 09:43:27 pm »
Forge is pretty quiet, but thats with my exhaust, which is louder than most.. It gives a nice sound, wouldn't say its much quieter than the open filters, a nicer sound in my opinion though..
Outside its loud..
« Reply #100 on: September 08, 2009, 09:48:09 pm »
Those figures are well within oem spec...   :happy2:
Offline KRL
  • -Receive: 29
« Reply #101 on: September 08, 2009, 10:15:45 pm »
As Balicus said these figures are good  :happy2:
Your LTFT is Lambda (Partial) - Self-Adaptation = 2.3%.  This is a stock like figure and shows your ECU currently is not having to compensate for either too much or too little air coming in compared to what the MAF sensor is seeing.  Keep an eye on this over time and see if it changes.  If its staying the same it means the ECU has already stabalised and it looks like the MAF housing ITG have designed is flowing as the stock one would which is great as tuners such as APR and Revo leave the MAF scaling at stock unless you are going a BT.
How many miles have done with the ITG installed?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #102 on: September 08, 2009, 10:17:25 pm »
^^^ nearly 3k miles so far  :happy2:
Offline KRL
  • -Receive: 29
« Reply #103 on: September 08, 2009, 10:19:19 pm »
This can be logged by doing a WOT run through the rev range and logging block 002.
Offline KRL
  • -Receive: 29
« Reply #104 on: September 08, 2009, 10:20:56 pm »
ITG gets a thumbs up from me then  :congrats:
