Author Topic: Air con parts  (Read 2372 times)
Offline alexmccabe
    • Alex McCabe
Air con parts
« on: July 18, 2013, 10:43:47 am »
Just went and got my air-con re-gassed in the hope that would sort the no air-con issue I've been having. Turns out not. Although there is no leak, the air-con isn't turning on. They reckon that it is either the air-con pump of the pressure sensor that is broken, but would need some time to check. As they order their parts from GSF or Euro Car Parts, i'd rather not go down the third party route.
Anybody know the part numbers for either part? A price would be appreciated too, though I can get that myself  :happy2:
MK5 Golf GTi 197BHP Tornado Red
Offline alexmccabe
    • Alex McCabe
Re: Air con parts
« Reply #1 on: July 18, 2013, 11:12:08 am »
OK so after some research it's quite possible the compressor has failed, which is a common fault that VW don't offer to fix. £550 for the compressor then labour... :sad1:
Offline coolhandluke
  • -Given: 28
Re: Air con parts
« Reply #2 on: July 18, 2013, 12:16:44 pm »
Some info http://www.mk5golfgti.co.uk/forum/index.php/topic,69533.0.html
Offline trs888
  • -Given: 17
  • -Receive: 20
Re: Air con parts
« Reply #3 on: July 19, 2013, 03:14:41 pm »
im on a similar thing for my caddy. There was a High pressure sensor G65 fault on VCDS. i have had it regassed at kwik fit but still didnt work and the error came back after clearing it.
i ordered a new sensor from VW @ just less than £50 and fitted it myself. The error cleared and has not come back, just LOW PRESSURE, so Its in at VW now getting regassed. Picking it up later today so hopefully just sensor was fooked.
Offline trs888
  • -Given: 17
  • -Receive: 20
Re: Air con parts
« Reply #4 on: July 19, 2013, 08:46:46 pm »
well, got it back from VW tonight, air con is cold as ice again. im going to scan it in the morning to make sure there are no errors.
Cost of VW:
£70 diagnostics
£65 High Pressure Sensor (G65)
£70 fitting (probably)
£69 Regas
Potential Total: £274
actual Spend:
£49.00 Sensor
£69 re Gas
Fitting £ FREE BY ME  :grin:
Diagnostics  £ FREE BY ME  :grin:
Total £118 plus a massive  :grin:
Saving £156
« Last Edit: July 19, 2013, 08:48:36 pm by trs888 »
Offline jaffa
  • -Receive: 44
Re: Air con parts
« Reply #5 on: July 19, 2013, 08:56:39 pm »
didn't know you fitted it
Offline SooperD
Re: Air con parts
« Reply #6 on: July 19, 2013, 10:20:44 pm »
I also have the same issue so Im praying its a sensor and not the compressor.. How easy was it to fit? Ok for a mechanical Newbie like me to find and fit?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: Air con parts
« Reply #7 on: July 19, 2013, 10:40:19 pm »
Don't rule out the condenser - had mine with VW twice after having it regassed and they couldn't find a leak until they took the front of the car apart and found that the condenser was the culprit / the dryer recover part to be exact
Offline SooperD
Re: Air con parts
« Reply #8 on: July 19, 2013, 11:29:37 pm »
Anything other than a sensor is gonna be expensive right? If it wasnt for this damn Heatwave It probably wouldnt even bother me  :rolleye:
Offline Bradruss
Re: Air con parts
« Reply #9 on: July 20, 2013, 09:45:29 am »
Same problem with mine, no ac - do I regas it or go to the stealers... :(
Offline trs888
  • -Given: 17
  • -Receive: 20
Re: Air con parts
« Reply #10 on: July 20, 2013, 09:57:13 am »
hah yes ok YOU fitted the ACTUAL sensor but we took the front apart together and put it back together.  :signLOL:
Offline Bradruss
Re: Air con parts
« Reply #11 on: July 21, 2013, 02:18:51 pm »
Regased mine today and its ice cold again - happy! :)
Offline alexmccabe
    • Alex McCabe
Re: Air con parts
« Reply #12 on: July 22, 2013, 08:44:00 am »
When I had it re-gassed they vacuumed it and it held the vacuum, so fingers crossed, there is no leak.
Cost of VW:
£70 diagnostics
£69 Regas
actual Spend:
£49.00 Sensor
£69 re Gas
Saving £156
Quite a saving. Where did you get the sensor?
Offline exodus_ste
Re: Air con parts
« Reply #13 on: July 23, 2013, 12:10:49 pm »
^^^ I also need this info please!  :smiley:
Offline jaffa
  • -Receive: 44
Re: Air con parts
« Reply #14 on: July 23, 2013, 12:46:15 pm »
got the sensor from vw i think it was around the £40 mark
