Author Topic: Tell me about your squeaks...  (Read 1332 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« on: July 18, 2013, 02:38:56 pm »
Ok I have a demonstrable squeak coming from my engine bay... basically on a slight decline if i try and reverse up the slope with handbrake slightly on to create more resistance and bring the clutch in slowly on low revs letting the revs die more I get an annoying squeak...
Anyone had similar and what was it... booked in next friday to have it investigated further as the garage weren't able to hear it, till i got there to collect and demonstrate it...
Anyone...
Diesel Daily Hack.
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: Tell me about your squeaks...
« Reply #1 on: July 18, 2013, 04:02:25 pm »
Mine makes a squeek if I pull off with low revs with the air con on, if the air con is off its fine
Offline CAPTAIN BRITAIN
« Reply #2 on: July 18, 2013, 04:17:08 pm »
I have this squeal at low revs also, haven't tried to pull away with air con off though.  I'd like to know what's causing it.
Offline doylebros
« Reply #3 on: July 18, 2013, 08:29:17 pm »
Possibly corrosion on the brake disc or discs (inboard side) could cause than - or a sticky pad!
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #4 on: July 19, 2013, 08:35:01 am »
Mine happens when cars stationary...
Diesel Daily Hack.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #5 on: July 19, 2013, 12:29:54 pm »
My ED30 started about 6 days ago with a really annoying rattle/vibration which sounds like it's some where in the cabin/dash area?. Tried everything I can think off but no joy. Only does it on tick over, soon as you set off it stops  & when engine is running & you get out the car it cant be heard so def on the inside .  Doing my head in now!!!!!!. :rolleye:
« Reply #6 on: July 19, 2013, 12:54:47 pm »
used to have a squeak near the glove box--but sorted it now
