Author Topic: Replacing Alloy VW Badges  (Read 2151 times)
Offline nelmser
« on: July 18, 2013, 08:26:37 pm »
Just bought these from eBay:
http://www.ebay.co.uk/itm/271225756624?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Turns out I bought the wrong size so I'll have to reorder....
Are these easy to fit? I don't really want to remove the wheels... They look like they can just clip in?
2006 MK5 GTI 2.0
  • -Receive: 291
Re: Replacing Alloy VW Badges
« Reply #1 on: July 18, 2013, 08:30:47 pm »
It's a lot easier it you remove the wheels as they just push out from behind. You can use a flathead or similar to tease them out but you run the risk of damage.
Offline doylebros
« Reply #2 on: July 18, 2013, 08:37:55 pm »
If the old ones are finished (whiteworm) just drill a small hole in them - this allows you to pull them off (your prefered method - small screw and Pliers for me) without removing the wheels - new ones then just press in by hand!
Job done in minutes, if not and you want to keep the old ones - wheels off and knock out from the rear of the wheel.
  • -Receive: 427
« Reply #3 on: July 18, 2013, 09:02:33 pm »
As above, if they have whiteworm then drill a wee hole (carefully) and Roberts your mothers brother. If you want to keep them. Then use a plastic trim tool.
Offline chrispygti
« Reply #4 on: July 18, 2013, 10:05:13 pm »
What size are the standard centre caps for 18 inch monzas?
Offline doylebros
« Reply #5 on: July 18, 2013, 10:08:31 pm »
Best measure the ones fitted  - 65mm outside diameter rings a bell though!
  • -Receive: 427
« Reply #6 on: July 18, 2013, 11:17:42 pm »
Size is 65mm outside and 55mm inside IIRC. If you need it, the OEM part number is 3B7601171XRW and they cost about £7.50 each.
Offline fonzie2107
« Reply #7 on: July 21, 2013, 07:01:24 pm »
Took mine off earlier today part number on the inside is 3B7 601 171 plenty available on ebay. Replica ones are £7 a set
Offline Bradders
« Reply #8 on: October 05, 2013, 10:47:20 am »
Easiest way is to tap a hole with a small screwdriver then prise them out.....simples.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #9 on: October 05, 2013, 06:02:01 pm »
Blowtorch: melt the barstewardss :wink:
'07 Red manual
