Author Topic: Steering wheel problems - advice needed  (Read 811 times)
Offline Homer
« on: July 19, 2013, 06:56:28 pm »
Hi folks, I recently let my sister borrow the car and she returned it saying she had put air in one of the tyres as it looked flat. I then took the car for a drive and noticed the steering felt different; i.e. I was having to turn it a lot more i either direction for the car to turn how I wanted it to.
I then went to a petrol station and checked the air in the tyre- she had put it to 38 psi... anyway i put it to the right psi but this has not solved the problem. Now when the wheels are pointing straight the steering wheel sits a bit to the right.
what would be the easiest fix for this? Thanks.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Steering wheel problems - advice needed
« Reply #1 on: July 19, 2013, 07:06:06 pm »
Alignment.
Offline edd666999
  • -Receive: 89
« Reply #2 on: July 19, 2013, 09:44:55 pm »
So your sister hit a curb or a pot hole and thought she had best check tyre pressure so you don't notice anything, filled the tyre up too much.
Now your out of alignment and full of air!
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #3 on: July 19, 2013, 10:27:48 pm »
Thought this aswell. Have an accidental thank you too!!
Offline edd666999
  • -Receive: 89
« Reply #4 on: July 19, 2013, 11:10:44 pm »
Why thank you too
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #5 on: July 20, 2013, 02:47:47 pm »
Thank you kind sir  :grin:
