Author Topic: Should I start saving?  (Read 1379 times)
« on: July 19, 2013, 08:08:46 pm »
Did a routine scan on my car and these two errors popped up. Car was otherwise running ok without showing a CEL in dashboard.
2 Faults Found:
012600 - Intake Manifold Runner Control
               P3138 - 008 - Regulation Deviation - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 42961 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 1381 /min
                    Load: 19.2 %
                    Speed: 0.0 km/h
                    Temperature: 52.0°C
                    Temperature: 48.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.192 V
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 42972 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 90.0°C
                    Temperature: 45.0°C
                    Voltage: 13.208 V
Did a basic setting for Intake Manifold Runner after clearing the fault codes and the errors disappeared on rescan.
Should I now be worried about this being the start of my throttle body beginning to fail?
Offline edd666999
  • -Receive: 89
Re: Should I start saving?
« Reply #1 on: July 19, 2013, 08:29:34 pm »
New engine by the looks of things  :grin:
I'd be saving for the 70mm throttle body aks is selling.
Offline flyboy1976
« Reply #2 on: July 19, 2013, 08:40:10 pm »
I have a flap intake motor for sale if you need one, ive had this issue but mine showed up with a throttle body G69/G188 code which is the tell tale sign.
« Reply #3 on: August 10, 2013, 10:31:04 pm »
Well Cel popped up tonight and the three faults are stored including the dreaded G188 one. Looks like I'll be shopping for a new throttle body asap.  :sad1:
3 Faults Found:
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
               P1098 - 001 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 43618 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:41:49
             Freeze Frame:
                    RPM: 4261 /min
                    Load: 84.3 %
                    Speed: 113.0 km/h
                    Temperature: 90.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 002 - Signal Too Low
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 43621 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:44:17
             Freeze Frame:
                    RPM: 4254 /min
                    Load: 81.1 %
                    Speed: 82.0 km/h
                    Temperature: 90.0°C
                    Temperature: 24.0°C
                    Voltage: 14.224 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 43621 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 162 /min
                    Load: 74.1 %
                    Speed: 0.0 km/h
                    Temperature: 90.0°C
                    Temperature: 30.0°C
                    Voltage: 11.049 V
