Author Topic: Rear brake pads-what to get?  (Read 1272 times)
Offline Gasman
« on: July 20, 2013, 09:17:36 pm »
Evening all,
I've just bought my first GTI and absolutely love it!  Only slight complaint is some brake squeal at low speeds.  The front pads look almost new so I'm assuming its coming from the rears.  Can anyone recommend some good rear pads and where to buy them from?
Steel Grey GTI, 19" BBS RD383 wheels, R32 rear bumper, BCS R32 style cat back
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Rear brake pads-what to get?
« Reply #1 on: July 20, 2013, 10:04:00 pm »
You don't have to crazy with rear brake pads check out euro car parts :)
Offline Gasman
« Reply #2 on: July 20, 2013, 10:13:18 pm »
They are quite worn anyway so I may as well change them.  Ill probably just get VW to replace them then.
Offline Gasman
« Reply #3 on: July 20, 2013, 10:19:44 pm »
Thanks.  Just found these. Didn't realise they were that cheap!  I've got myself a Haynes manual and am tempted to do it myself now.  Is it easy enough to do?
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2005/p/car-parts/brakes/brake-friction/brake-pad/?101440328&1&04db17944df8a7c39e2879a90309ed296b0ce9d5&000036
« Reply #4 on: July 20, 2013, 10:46:06 pm »
Be aware that you will also need a wind back tool to retract the piston into the caliper.    :smiley:
Offline Gasman
« Reply #5 on: July 20, 2013, 10:50:03 pm »
If you do it yourself get the grease, it will stop them squeaking bud.  Pads are a simple job, just take your time. :happy2:
Yeah I've watched a couple of how to videos on YouTube looks simple enough.  Ill make sure I get the grease.
Offline Gasman
« Reply #6 on: July 20, 2013, 10:50:51 pm »
Yeah I've seen one on eBay for about a tenner ill get one cheers.
Offline Black9
  • -Given: 35
« Reply #7 on: July 21, 2013, 05:15:42 pm »
I have pagid rear pads on OEM discs. Work well but as mentioned u dont have to go crazy
Offline Gasman
« Reply #8 on: July 21, 2013, 09:01:06 pm »
Just noticed my rear discs have quite a bit of a lip on them and are quite crusty as well.  Think ill do these at the same time.  Has anyone got any hints/tips on what to look out for when doing this? Is it necessary to drain off some brake fluid prior to doing this?  As some of the videos on YouTube don't mention it and some do?
Offline Gasman
« Reply #9 on: July 21, 2013, 10:03:27 pm »
Yeap, you'll need a M14 spline bit, some Plusgas and a breaker bar to get the carriers and therefore discs off (you may not need the breaker bar, but it makes it a lot easier).  Go easy on the disc locator screws, if you round them, you'll have to drill / screw extract them out.
Ok thanks.  Plusgas Aerosol or the tin?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #10 on: July 22, 2013, 05:52:36 pm »
Plusgas won't really penetrate into the threads, at least not until you've undone the bolt a bit. Concentrate on getting a really good fit with the M14 into the bolt; clean the bolt if required. Then concentrate on getting a good purchase and angle of attack on the bolt.
The Plusgas helps a lot when you're unthreading the bolt, but I think it's a placebo effect for actually 'uncracking' the bolt initially.
'07 Red manual
