Author Topic: Leak in Air Intake System  (Read 2126 times)
calais250
« on: July 22, 2013, 08:38:33 am »
Hello does my MAF sensor need replacing?
or PCV, I inspected the hose from the MAF to the intercooler under the car and they looked good
i can't see a leak anywhere.
so has anyone had this problem before?
thanks for any suggestions
4 Faults Found:
008825 - Leak in Air Intake System
               P2279 - 002 -
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 158351 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:11:04
             Freeze Frame:
                    RPM: 819 /min
                    Load: 14.9 %
                    Speed: 0.0 km/h
                    Temperature: 87.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.224 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100100
                    Fault Priority: 0
                    Fault Frequency: 5
                    Mileage: 158351 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 84.0°C
                    Temperature: 57.0°C
                    Voltage: 12.319 V
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected. - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 158356 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:12:04
             Freeze Frame:
                    RPM: 922 /min
                    Load: 14.9 %
                    Speed: 0.0 km/h
                    Temperature: 85.0°C
                    Temperature: 39.0°C
                    Voltage: 14.224 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 158373 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:07:13
             Freeze Frame:
                    RPM: 794 /min
                    Load: 14.9 %
                    Speed: 0.0 km/h
                    Temperature: 74.0°C
                    Temperature: 21.0°C
                    Voltage: 14.351 V
Readiness: 0000 0101
Monday,22,July,2013,16:57:59:32264
VCDS Version: Release 11.11.3
Data version: 20120401
                Address 01: Engine       Labels: 06F-907-115-AXX.LBL
Control Module Part Number: 1K0 907 115 J    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0030
           Software Coding: 040300431C070160
            Work Shop Code: WSC 30081 959 88100
                      VCID: 2D5B176DB40A1F1
1 Fault Found:
               P2279 - 002 -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 158680 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 04:54:00
             Freeze Frame:
                    RPM: 776 /min
                    Load: 14.5 %
                    Speed: 0.0 km/h
                    Temperature: 81.0°C
                    Temperature: 37.0°C
                    Voltage: 14.224 V
Readiness: 0110 0101
