Author Topic: P0441 & P2187 codes. help please  (Read 3796 times)
Offline mac3582
« on: July 22, 2013, 12:47:17 pm »
Hi,
really need some help.
about a month ago my CEL came on. my friend checked it with his snap on scanner and it came up with the P0441 evap code and a maf sensor code which im afraid I cant remember. he cleaned the maf and cleared the codes but they came back,  so I tried replacing the charcoal canister, but they came back again. I have now had the car checked with vag com and the only code that comes up is P2187 system too lean at idle. im not sure which direction to go in, do I replace the maf, or maybe the n80 valve or double check valve or maybe even the injectors. it does have a seriously loud tick when I accelerate and when its idling, which I had vw look at quite a while ago, they said it was just loud injectors and normal.
any help would be appreciated.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: P0441 & P2187 codes. help please
« Reply #1 on: July 22, 2013, 12:51:52 pm »
http://wiki.ross-tech.com/wiki/index.php/18619/P2187/008583
18619/P2187/008583 - Bank 1; System too Lean at Idle
 Possible Causes
 Injectors leak/blocked
 Air Intake Leak (after MAF)
 Exhaust Leak
 Possible Solutions
 Check Mass Air Flow Sensor (G70)
 Check Injector(s)
 Check Fuel Pump
 Check Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
 Special Notes
 When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve  If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
Silver is the way !
Offline mac3582
« Reply #2 on: July 22, 2013, 07:21:16 pm »
thanks for the info scopes. would there be any running problems if the maf or the fuel pump were faulty. the car seems to run fine.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #3 on: July 22, 2013, 09:31:33 pm »
Hey Matey
No worries, your best bet is to goggle P2187 code, and have a read to see if other guys are having the same problems as yourself...
It could be something as simple as a DV needs replaced, i'm not to sure on your cars history...
Silver is the way !
