Author Topic: Temperature WTF!!!???  (Read 1524 times)
Offline Jussa
  • Bicester
« on: July 22, 2013, 01:05:17 pm »
It's about 33 degrees today in London, and my temperature gauge says 21.5 and took around an hour to move to 22  :scared:
It hasn't moved from 22 - does anybody have any suggestions???
Knackered thermometer maybe?
Where are these located and are they expensive and/or easy to swap??  :confused:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Temperature WTF!!!???
« Reply #1 on: July 22, 2013, 01:37:47 pm »
it is in or behind the lower grill
Cluster and Key coding
Location Great Yarmouth
Offline Jussa
  • Bicester
« Reply #2 on: July 22, 2013, 01:45:10 pm »
Do you reckon it's the thermometer, or is it a sensor?
Is it easy to swap?
Offline OSB
  • -Given: 32
« Reply #3 on: July 22, 2013, 01:55:56 pm »
Most likely the sensor
Offline Jussa
  • Bicester
« Reply #4 on: July 22, 2013, 02:10:46 pm »
Thanks guys - is it expensive and an easy swap?
Also, will it affect how the car gives me hot or cold air by way of the climate control?  :confused:
Offline Jussa
  • Bicester
« Reply #5 on: July 22, 2013, 08:25:54 pm »
Disconnected the battery, then reconnected afte a few minutes, it then showed the correct temperature of 36 degrees.  Problem now though is its still saying 36 degrees and its clearly a lot cooler   :confused:
« Last Edit: July 23, 2013, 12:33:20 am by Jussa »
