Author Topic: Brake change sign  (Read 500 times)
Offline Rustybear
  • -Given: 243
Brake change sign
« on: July 22, 2013, 08:21:09 pm »
Round single on dashboard has come on. I know it means change pads but which ones fronts back? Do they both have sensors? Last question, prices?
Offline skard
  • -Receive: 245
Re: Brake change sign
« Reply #1 on: July 22, 2013, 09:21:41 pm »
It is the front (passenger?) side that has the sensor loom.
If you want OEM standard then TPS, or a VAG dealer, or not the cheapest ones from Eurocarparts or GSF.
If you are running standard brakes on a GTI then the front pads from a 2.0TDI and 2.0FSI are also the same.
