Author Topic: vw Kenwood system can you connect this to cd changer  (Read 1675 times)
Offline gjseb16
« on: July 23, 2013, 07:34:00 am »
as above peeps can you connect Kenwood dnx520vbt to your stock cd changer if so how pleased
cheers Gordon
Offline gjseb16
Re: vw Kenwood system can you connect this to cd changer
« Reply #1 on: August 26, 2013, 12:01:36 pm »
any one any ideas
Offline muddyfox480
« Reply #2 on: September 05, 2013, 11:23:05 am »
I was contemplating this; as the units can be had fairly cheap here in Germany.  However from my extensive searching, it appeared the answer was no, unless you wanted to cut a cable and make sure the wires were to the correct pins in the Kenwood format.  I don't believe there is a cable adapter that will help :(
Best is to bite the bullet, lose the CD Changer, or see if a Kenwood one would fit under the armrest.
Sorry it's not better news.
I was adament that if I have the CD changer I wouldn't want to lose it, despite the options and connectivity the Kenwood unit offers; I guess I'm a bit stubborn like that!
