Author Topic: Aircom pressure switch  (Read 1079 times)
Offline exodus_ste
« on: July 23, 2013, 12:06:25 pm »
Hi guys
After a failed attempt at regassing it seems i need the pressure switch just behind the radiator on the offside. Can anyone tell me the part number so i can get a price for one?
Cheers  :happy2:
Offline xjay1337
  • -Receive: 377
Re: Aircom pressure switch
« Reply #1 on: July 23, 2013, 12:20:42 pm »
The only thing on ETKA I can see that is sensor related is 1K0 959 126 B
Later revisions may be available. VW would also be able to provide that if you asked them.
Offline gazbutS3
« Reply #2 on: July 23, 2013, 05:04:37 pm »
Had this replaced on mine after a failed re-gas attempt,  becoming a common issue apparently to such  an extent the small independent I use carries them in stock. Unfortunately I don't have the part number to hand
Offline MikeA
« Reply #3 on: July 23, 2013, 05:23:48 pm »
Had my one replaced 18 months ago and invoice states 1K0 959 126D.   Also worth checking the valves under the plastic caps where the gas goes in,  my A/C stopped working again and found these bubbling the gas out   :surprised: just ordered via TPS and they are £8.20 each
Current Mk7 2016 5dr GTi Clubsport Edition 40 DSG - No. 403
Tornado Red, Dynamic Chassis Control, Rear View Camera and 19" Brescia Alloys
Previous MK5 2007 3dr Edition 30 Manual - No. 376
Black, Rear parking sensors, Winter pack
Offline nath
« Reply #4 on: July 24, 2013, 01:33:00 pm »
Does this show up as a fault code : :confused:  if not how do you check?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=n67jnjtejau174jqg89s3a25vv&/topic,19740.0.html
« Reply #5 on: July 24, 2013, 01:41:34 pm »
Well... it will show up as a fault when your coolant level drops. They usually leak.. as opposed to the sensor itself being faulty.
Offline xjay1337
  • -Receive: 377
« Reply #6 on: July 24, 2013, 04:38:19 pm »
If you scan your car you will have a fault in your HVAC section...
It's normally an electrical sensor failure rather than anything which would effect coolant.
« Reply #7 on: July 24, 2013, 04:44:26 pm »
They usually leak mate...  ended up with no gas in the system and A/C not working
Offline gazbutS3
« Reply #8 on: August 15, 2013, 10:42:44 am »
As above, the they leak past the electrical connectors in the plug
