Hi, please help me, vcds in engine fault code:
08801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P2261 - 008 - Implausible Signal - Intermittent
I replace N249 DV , old: 06F145710G new is : 06H145710D
error is back..
i try change N75 ( 06F906283F), and Pressure Control Valve (PCV)
error back again :(
please help me.
engine info: BWA 2.0tfsi 147kW (2008)
thanks
fault codes:
readlines after fault code
Set readlines
readlines done:
after erase dtc no fault codes.. but fault code is back(+ 6000rmp), fault code is back and readline is again failed or incomplet...
