Just drove home from work no problem, half an hour later car wont start! When ignition is on both fans kick in and run continuously and the temp gauge is showing nothing at all. Car turns over but will not fire. VCDS cant connect to the engine controller and also dsg lights are flashing eg all of them pnrd etc....HELP!
VCDS log.......
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ5W241797 Mileage: 132910km/82586miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine Labels: None
VCID: 55AB9F8DBC1A771
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 M HW: 02E 927 770 AD
Component: GSG DSG 041 0824
Revision: 00004010 Serial number: 00000504110582
Coding: 0000020
Shop #: WSC 01279 785 00200
VCID: 1D3BC7ADC4AAEF1
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0004738
VCID: 3A712C317544B89
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CDDDA694F90D69
1 Fault Found:
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001696939
Coding: E58D8F2600041819001400001400000000087F075C
Shop #: WSC 12345 123 12345
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00480286
Shop #: WSC 12345
2 Faults Found:
01502 - Bulb for Rear Fog; Left (L46)
012 - Electrical Fault in Circuit
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: 08 AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0C0THA
Coding: 0012344
VCID: 377735054656A51
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 521 0050
Coding: 0010042
VCID: 356B3F0D5C5A571
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 960 D
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0001403
Shop #: WSC 01179 210 93569
VCID: 30650E19A338729
1 Fault Found:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001054110B34
Coding: 3F0F0340070001
VCID: 2953E37D80E2031
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 132915 km
Time Indication: 0
Date: 2000.00.00
Time: 13:42:48
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0812
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0122
Coding: 0000052
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 31630B1DA8327B1
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 2880 km
Temperature: 38.0°C
Voltage: 12.40 V
Voltage: 12.30 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 19D802487F2D8505481AC69010CC
Shop #: WSC 01392 785 00200
VCID: 78F5F6390BC86A9
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 1K0 951 177 A
Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 L
Component: Radio BVX 014 0022
Coding: 0040402
Shop #: WSC 00000 785 00200
VCID: 2F670D65BE066D1
End ---------------------------------------------------------------------
