Author Topic: Help needed getting through to the cabin  (Read 961 times)
Offline jamiew
« on: July 28, 2013, 12:23:09 pm »
I am trying to run my turbo guage hose from the engine to cabin but just cant fit a suitable way, any hell guys, and any one in essex who may be able to give a helping hand if i drove to them
Thanks allot guys
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
Re: Help needed getting through to the cabin
« Reply #1 on: July 28, 2013, 12:26:56 pm »
take the battery and the battery tray out
you will see some wires going in to the firewall and they comt out behind the glove box
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline jamiew
« Reply #2 on: July 28, 2013, 12:30:09 pm »
Thanks for ur reply, i think i may have trouble getting the battery out as i have an itg maxogen right up against it. Also how easy is it to get from behind glove box to drivers footwell?
Offline edd666999
  • -Receive: 89
« Reply #3 on: July 28, 2013, 01:41:07 pm »
i just took the carpet away under the glove box, and there is a sponge type material you can remove too, you will be able to see a port through into the engine bay, i stuck a screw driver through (quite big/thick one) then a smaller/thin one, i then put the boot pipe over the thin screw driver, covered it in duct tape, and pulled through...oh and wd40!
Just be careful with A the wires under the passenger seat and B the port that you decide to use, if there are already wires running through there you dont want to damage anything.
