Author Topic: Fitting Towbar electrics  (Read 2302 times)
Offline Bolton_gti
« on: July 28, 2013, 12:40:14 pm »
Hi all,
Hope someone could help me out on this topic... As daft as it seems I've fitted a quick release tow bar to my gti and need advice/ guidence on getting the electrics hooked up.
Does anyone know if I require a Relay? or could it literally be wired up to the lights?
This is my first towbar and im a little clueless
Appreciate any help if someone has had experience with this or could share some photos.
Thanks,
  Richard
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Fitting Towbar electrics
« Reply #1 on: July 28, 2013, 12:54:24 pm »
I removed a towbar a few days ago and the wiring I took out went from the towbar and into some sort of switch box and then joint to the rear lights.
Sent From My Samsung S3
Offline Bolton_gti
« Reply #2 on: August 09, 2013, 11:01:32 pm »
Right, bought a relay box which I've connected to the towbar electrics as instructed, then I connected all wires up from the relay box to relevant wires, earthed it and fed to a live feed but didn't work...
Then all my lights stopped working. Anyone know where I'm going wrong? Once I removed all the wiring things were back to normal
Any help would be appreciated
Richard
Offline Bolton_gti
« Reply #3 on: August 11, 2013, 03:42:35 pm »
Anyone help? :(
Offline Bolton_gti
« Reply #4 on: August 11, 2013, 03:42:41 pm »
Anyone help? :(
Offline biglad65
« Reply #5 on: September 06, 2013, 10:25:50 pm »
hi vw55raz what side of car was the bypass box at drivers or passengers also where was the permanant fused live feed picked up cheers
Offline biglad65
« Reply #6 on: September 06, 2013, 10:59:03 pm »
hi do you just take the bottom part of bumper off to fit the tow bar thanks
