Author Topic: Manifold Pressure / Boost Sensor (G31)  (Read 5830 times)
Offline edd666999
  • -Receive: 89
« on: July 28, 2013, 01:00:29 pm »
Ever since my brother bought his car he has had this error repeating,
when driving its an intermittent issue in low gear when you set off and move through the gears at low speed it kangaroos slightly.
I have driven it and didnt believe him at first but it happened to me too. Its like a misfire but only one and the rest of the rev range is fine.
Coilpacks and spark plugs have been done.
000566 - Manifold Pressure / Boost Sensor (G31)
               P0236 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 81
                    Mileage: 87687 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:16:30
             Freeze Frame:
                    RPM: 740 /min
                    Load: 23.5 %
                    Speed: 2.0 km/h
                    Temperature: 42.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
Where is this sensor? is it the map sensor built into the pipe that runs from the IC?
Offline edd666999
  • -Receive: 89
Re: Manifold Pressure / Boost Sensor (G31)
« Reply #1 on: July 28, 2013, 07:38:44 pm »
 :signLOL:
Its a leon cupra 2.0 tfsi by the way.
Offline edd666999
  • -Receive: 89
« Reply #2 on: July 29, 2013, 05:33:04 pm »
noone?
Offline adgti
« Reply #3 on: August 01, 2013, 12:13:21 am »
It is the map sensor on the pipe that goes from the tb to the intercooler. Replace it
