Author Topic: Is this normal?  (Read 1929 times)
Offline josh newman
  • Gt Tdi naughty naughty
Re: Is this normal?
« Reply #15 on: August 06, 2013, 01:51:04 pm »
I just fitted a neuspeed intake at around 3000 rpm its sounds like a screech or a whistle on hard acceleration but if driven with gradual acceleration
it doesn't make the noise I was wondering if it was more to do with the diverter valve but surely it would have made that noise with standard intake if it was the diverter
it is annoying tho
Offline Rumple
  • Das Original.
Re: Is this normal?
« Reply #16 on: August 06, 2013, 04:58:59 pm »
Yea same here, Ive since been told its the noise the K03 makes when spooling? don't know how correct that is but apparently the increase in airflow has this effect on it.
Ive got quite used to the sound now and tbh its not that bad but when I floor it the car sounds like some silly jap toy, I doubt its the DV I only changed mine 3weeks ago to a revision D.
Although when I let off, the pressure release does sound like a dump valve -.-
Black 3dr Edition 30 DSG
Offline josh newman
Re: Is this normal?
« Reply #17 on: August 06, 2013, 06:41:26 pm »
same mate maybe it is just a common noise it doesn't bother me I was just worried I was losing boost pressure sounded at first as if it was dumping from the turbo lol
I think im going to upgrade to a revision d
