Author Topic: Jom coilovers 2 low ?  (Read 3124 times)
Offline Ducky76
« on: July 30, 2013, 10:36:00 am »
Hi I be just bought some jom coil overs and now wishing Ide spent 3 times as much , well I've fitted them and the fronts are as high as they can go and I can still only just fit my fingers up 2 the knuckle in the arch gap on 19 thou , but I've had 2 do the arch mod 2 stop rubbing they're so low?!?! Anyone else got this problem??
Cheers andy
Offline VWPalmer
Re: Jom coilovers 2 low ?
« Reply #1 on: July 30, 2013, 11:02:11 am »
First I've ever heard of this with jom's. Out of all the cheap coilovers there are normally the ones that wont go low at all, I ran a set on my gti for a couple of weeks while I waited for my new coilovers after the air ride and they were almost wound all the way down and had a coil cut off them and they weren't really low.
Do you have any pics of them fitted? like the strut itself not the whole car?
Offline Ducky76
« Reply #2 on: July 30, 2013, 12:32:10 pm »
No no pics , but the collar is wound right 2 the top and I've 15 mm gat but can wind down 80mm ?  It would be low as hell  :confused:
Offline VWPalmer
« Reply #3 on: July 30, 2013, 05:45:25 pm »
Sounds odd, my mate had these same coilovers on his jetta and his wouldn't go low enough to tuck tire on 19's. I don't know what else to suggest without seeing pics.
Offline Ducky76
« Reply #4 on: September 20, 2013, 08:39:57 pm »
Better late than never
Offline CJS-90
« Reply #5 on: September 25, 2013, 09:36:33 am »
Surely you wanted coilovers for going lower though!?
Offline Ducky76
« Reply #6 on: September 25, 2013, 10:47:31 pm »
Lower than my ebach sport lines but not rubbing and bouncy , it's on 18 s now standard set up and rubbing and I can only go lower !!?? I've rang awsome with the spring number they have 2 be wrong that's the only answer I think 2 my mind   :confused:
Offline benj1989
Re: Re: Jom coilovers 2 low ?
« Reply #7 on: September 25, 2013, 11:43:18 pm »
Sure there fitted properly?
Sent from my HTC One using Tapatalk 2
Offline Ducky76
« Reply #8 on: September 26, 2013, 07:38:00 pm »
The shocks  look fitted correct 2 me but I'm no mechanic they look dearer right in the wishbone bit and top mount looks right 2 me !?  I've been in touch with awsome where I got the kit from and the springs have the  correct code on them so I've taken several photos and sent them they are going 2 talk 2 Jom and get back 2 me
