Author Topic: Airbag Warning Light  (Read 3000 times)
Offline darrens
« on: August 21, 2009, 08:41:03 am »
I was removing the ipod lead from the stereo last night and had unplugged the airbag warning light.  I wanted to check the stereo was working before putting the dash back in place so silly me turned on the ignition without reconnecting the airbag warning light and I now have a airbag error light.
I know this can be removed with vagcom however I don't have it and don't know anyone with it (I'm from N Ireland).  Is there any other way to get rid of it without a trip to the dealers?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Airbag Warning Light
« Reply #1 on: August 21, 2009, 08:42:50 am »
Sorry dealers or VCDS/VAGCOM for this one.
Offline 20vt2008
« Reply #2 on: August 21, 2009, 08:54:22 am »
Try leaving the battery totally disconnected for 30 mins you might get lucky and clear the faults
3DR Reflex Silver GTI - Revo Stage 2 - Revo SPS + - Neuspeed Intake - 3" DP - Version 'D' DV - Eibach Sportlines Plus More To Come!
Offline darrens
« Reply #3 on: August 21, 2009, 09:01:40 am »
Thanks.  Is leaving the battery disconnected likely to affect anything else apart from clocks etc?
« Reply #4 on: August 21, 2009, 09:20:30 am »
Not really
« Reply #5 on: August 21, 2009, 09:40:31 pm »
Where abouts are you mate as someone nearby may have a VCDS cable handy and willing to clear any fault codes.
« Reply #6 on: August 21, 2009, 11:31:27 pm »
....Yes.
- If you have a remap, some (such as Revo) will automatically revert back to 'stock'. This is actually a good thing and not a problem because you can simply reload the 'performance' map via the OBD port.
- It can also reset some of your SatNav stored info and settings to default on aftermarket built-in systems such as Alpine and Pioneer.
