Author Topic: steering torque sensor  (Read 15778 times)
Offline GTI-MATT
  • GTI-MATT
« on: August 03, 2013, 02:36:28 pm »
I changed my front hubs, wishbones on brake calipers for the s3 setup this moring and after starting the car back up the steering light didnt go out it stayed a yellow colour. I then got a fault code 00573 steering torque sensor g269. I then checked and ajusted the tracking and cleared the fault code light went out. I then turned ignition off and restarted the car and light stayed on again with the same fault code! Could some one please help? Car also drives fine with the light on?
Offline GTI-MATT
  • GTI-MATT
Re: steering torque sensor
« Reply #1 on: August 03, 2013, 09:13:35 pm »
Can anybody help with some usefull information? Or if someone has cured this fault?
Offline edd666999
  • -Receive: 89
« Reply #2 on: August 03, 2013, 09:49:10 pm »
Checking Steering Torque Sensor (G269)
Prerequisites:
Ignition ON
Engine ON (Idle)
System voltage at least 11.0 V.
[Select]
[44 - Steering Assist]
[Meas. Blocks - 08]
Group 001
[Go!]
Field 2: Steering Torque Sensor (G269)
Turn the Steering Wheel multiple times completely to the left and right. The Torque Values should change.
If the Torque Values do change, it's most likely an intermittent Fault in the Wiring/Connectors.
If the Torque Values do NOT change, the Sensor itself or the Power Supply (Terminal 15) might be faulty.
Group 004
[Go!]
Field 2: Power Supply (Terminal 15), Specification: "Term. 15 ON"
[Done, Go Back]
[Close Controller, Go Back - 06]
Offline flatout
« Reply #3 on: August 03, 2013, 10:15:50 pm »
have you tried driving it,the light should go off then.when i have my battery off i had the light on,it stayed on till i got up to about 15mph then went off,worth a try mate.
stage 2+ Grey Ed30..DSG 362 BHP.380 lb/ft.....Also Statller Tuned :)
Offline GTI-MATT
  • GTI-MATT
« Reply #4 on: August 03, 2013, 10:48:23 pm »
Yeah ive tried driving it light stays on mate  :confused:
Offline edd666999
  • -Receive: 89
« Reply #5 on: August 04, 2013, 01:09:28 pm »
What happened when you tried what i suggested?
Offline GTI-MATT
  • GTI-MATT
« Reply #6 on: August 04, 2013, 01:23:20 pm »
Aven had chance yet mate cables in work il av to ava look tomorrow. Ive heard storys if you hit the track rod end to hard to break the taper where it goes into the hub u could damage the rack? Surley a good pot hole would give more of a impact than when i hit it?
Offline GTI-MATT
  • GTI-MATT
« Reply #7 on: August 07, 2013, 09:34:37 pm »
Just checked the torque sensor using ross tech and all the torque values are moving as i move the steering wheel plus power supply terminal15 is on. I can clear the dtc and the yellow light will stay out while i drive the car but as soon as i turn the igntion off remove the keys then restart the car the light reappears and stays on! Anybody got any ideas please?
Offline Baz300
« Reply #8 on: August 08, 2013, 06:51:06 am »
For the yellow steering wheel light.
Start the car and make sure the steering wheel is in the center
Turn the wheel to full lock left and hold it there for a few seconds
Turn the wheel to full right lock and hold for a few seconds
Go for a slow drive and it should go out
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: August 08, 2013, 07:37:16 am »
If the above reset doesn't work then you need a new rack.
Follow AKS tuning on Facebook
Offline GTI-MATT
  • GTI-MATT
« Reply #10 on: August 09, 2013, 08:17:25 pm »
Fanx for the help guys but sadly i need a new rack have they got to be coded or any thing once the new one has been fitted? Anybody got a faultless second hand one lying about? Lol
Offline Baz300
« Reply #11 on: August 10, 2013, 07:03:22 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,70126.0.html
Any use?
Might as well fit an uprated ARB while everything is off the car :laugh:
