Author Topic: I've had the stage 1 guys....what's next in line?  (Read 7609 times)
Offline 18Edition30
« on: August 03, 2013, 09:52:43 pm »
Had the stage 1 map on the car for a little while me and love it!!
Now interested in the next mods to go to the next stage not yet...but in the future!!
Current mods are....pre cat delete, milltek cat back, VWRacing intake and stage 1 map, Eibach springs and VWRacing lower engine mount.
I'm thinking best to finish exhaust with downpipe and sports cat 100 cell or 200 cell first then maybe intercooler?
Or other way around?
Or both then stage 2 map, which is free apparently? Great if so!
What bhp and torque would this bring guys??
I spose clutch upgrade would be needed after that though!
Cheers fellas, I've got the bug from this place!!
« Last Edit: August 03, 2013, 10:15:25 pm by 18Edition30 »
Re: I've had the stage 1 guys....what's next in line?
« Reply #1 on: August 03, 2013, 09:55:53 pm »
get the brakes done
Offline 18Edition30
« Reply #2 on: August 03, 2013, 10:14:49 pm »
Yeah was worried about the extra weight of R32 ones so might just be disc and pad upgrade I think.
  • -Receive: 427
« Reply #3 on: August 03, 2013, 10:25:34 pm »
I go with...
Anti lift kit and poly bush front wishbone
Rear Anti Roll Bar
As for brakes, the NQSBBK is a lot lighter than the OEM set up and a lot better too.
Then a decent downpipe with 200 cell Cat Back and a stage 2 map.
Offline 18Edition30
« Reply #4 on: August 04, 2013, 08:54:33 pm »
Yes was looking into rear roll bar. Think anti lift kit may be a bit much for what I'm using the car for...I don't track it. May be wrong though.
Will look out for a milltek downpipe to finish the system and get stage 2 map. Still no intercooler needed then?.
What power does APR stage 2 get you to roughly?
Cheers guys!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=b37eos6o6lkb0h5mm98jb9ak50&/topic,19740.0.html
« Reply #5 on: August 04, 2013, 08:59:39 pm »
Why?? They work on the R32.....  :happy2:
Offline 18Edition30
« Reply #6 on: August 04, 2013, 09:15:23 pm »
Yeah I'm sure there great...but don't they slow you down?? They weigh a ton!
Offline skard
  • -Receive: 245
« Reply #7 on: August 04, 2013, 09:19:22 pm »
I do chuckle when people worry about the weight of R32 brakes, it isn't like the mk5 is the lightest car to begin with.
Offline Bow
« Reply #8 on: August 04, 2013, 09:29:20 pm »
Sorry to sound daft but what the hell are NQSBBK????. Heard it mentioned a lot on here and I don't have a clue
« Reply #9 on: August 04, 2013, 09:43:20 pm »
Well ill have a race with you and lets see if they are slowing me down......  :wink:
Offline 18Edition30
« Reply #10 on: August 04, 2013, 09:48:48 pm »
Sounds good.......APR vs REVO .......would be close both stage 1 and both with intakes...... :wink:
  • -Receive: 427
« Reply #11 on: August 04, 2013, 10:03:00 pm »
NQSBBK stands for "Not Quite So Big Brake Kit". Have a read of this, not all of it, just the first few pages will do.....
~~ Clicky here ~~
Looks like this....
Offline Bow
« Reply #12 on: August 04, 2013, 10:27:11 pm »
Thank you true about learning summit new everyday :-)
Offline Msportman
« Reply #13 on: August 05, 2013, 12:34:27 am »
APR Stage 2 means a new APR high flow RSC exhaust, APR fuel pump, APR / VWR intake, stage 2+ 3.1 map.
Should see 360+ dependant on car and dyno lottery.
I'm doing suspension KW clubsports then brakes before going Stage 2/3.
Car is running a Stage 1 map by Morego / BBR/ Gti Engineering.....very nice smooth map and would really recommend them too.
Pearl Black Edition 30 3 Door. DSG. (3rd Edition 30)
Maybe on the too do list: APR Stage 2+, KW Clubsports, Brakes, Diff.
Offline 18Edition30
« Reply #14 on: August 05, 2013, 09:17:36 pm »
I've got the VWRacing intake, just need the milltek downpipe and I'm there apart from fuel pump...is that really needed for stage 2? Or could I just have exhaust done then the stage 2 map?
What power would it make without the pump?
Also no intercooler needed?
I have Eibach springs and lower subframe mount so just want ARB for rear.
Will
