Author Topic: G188 error for my TFSI Sport :(  (Read 1811 times)
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« on: August 04, 2013, 09:28:35 pm »
Hello all! not posted in awhile since all I do is lurk but thought I share my recent fault event!
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
Dreaded TB!!!
06 TFSI Sport APR K04 tuned (100k+ Miles, WaterMeth/Spacer fitted)
Regardless if I am running map or stock it will throw me down to limp mode along with stuck on "EPC light"
It was on revision G (Siemens VDO) until it broke, I tried using a 2nd had revision "J" Continental VDO... Sadly still getting the same error :(
Tempted to try out a 2nd "Q" Latest revision and see if it will resolve the problem.
« Last Edit: August 04, 2013, 09:35:27 pm by cheungy »
MK2 PRE-FL SEAT LEON TFSI SPORT - APR K04
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=vfqvqm95qbc7baga50pqao502k&/topic,19740.0.html
Re: G188 error for my TFSI Sport :(
« Reply #1 on: August 04, 2013, 09:41:38 pm »
Yep... thats a new throttle body mate.  :sad1:
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« Reply #2 on: August 04, 2013, 09:46:50 pm »
already tried "used" J revision, going to try revision Q "used" next hope it does the trick...
« Reply #3 on: August 04, 2013, 09:48:20 pm »
How much are you paying for used ones? Speak to Alex... just get a new one and fix it 100%
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« Reply #4 on: August 04, 2013, 09:51:42 pm »
80.00 for the bay? if it fails, I'll return it... then go brand new when I get paid next heh!
« Reply #5 on: August 04, 2013, 09:53:06 pm »
He  speaks the truth Dave  :wink:
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« Reply #6 on: August 04, 2013, 09:54:30 pm »
 :drinking:prob will end up giving pots of gold to Alex  :drinking:
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
« Reply #7 on: August 10, 2013, 02:48:54 pm »
Problem fixed
Went from:-
06F 133 062 G (30-12-05) Siemens (Came with the Leon TFSI Sport 06)
to
06F 133 062 J (03-03-10) Continental (Brought from eBay not too long ago, failed & will be returning back)
to the latest...
06F 133 062 Q (10-05-120 Continental (Brought from eBay again, but this time success working fine!)
Fitted the throttle body this morning and it has solved my EPC issue, seems like Q is the way to go...
Hope this helps!
Offline sanj
  • -Given: 17
« Reply #8 on: August 10, 2013, 03:35:08 pm »
Nice to see you managed to get it sorted! :happy2:
