Author Topic: BSH Catch tank alternative fit.  (Read 31496 times)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: BSH Catch tank alternative fit.
« Reply #60 on: August 26, 2009, 09:42:56 pm »
^^^ they are listed earlier in the thread John  :happy2:
they cost about £2 each  :surprised:
« Reply #61 on: August 26, 2009, 09:43:15 pm »
you got a p/n for the spring clips Steve?
looks so much more OEM  :congrats:
....Part No. N 906 869 01 (23x12 Spring Type Clip)
^ According to Steve's earlier post.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #62 on: August 26, 2009, 09:45:02 pm »
cheers my bad for jumping in 1/2 way through a thread ,
£2  :booty:
Red ED35 5dr DSG
BLOG | BUILD
« Reply #63 on: August 26, 2009, 09:49:42 pm »
£2  :booty:
....£2 EACH!? :surprised: - How many of those oem clips are needed?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #64 on: August 26, 2009, 09:52:31 pm »
4 clips are needed.
« Reply #65 on: August 26, 2009, 09:53:09 pm »
£2  :booty:
Well none actually but if you want the oem look you'll need four.   :smiley:
Offline candy turbo
« Reply #66 on: August 26, 2009, 10:14:27 pm »
if your tight you could get away with 2 if you have oem engine cover :wink:
« Reply #67 on: August 26, 2009, 10:50:31 pm »
£2  :booty:
....Well, I wouldn't want anyone to feint from shock and horror when spotting that my clips in my engine bay weren't oem, would I! :evilgrin:
Methinks I'll wait and see what the supplied clips look like but one thing is clear: The Khazi Can needs removing from the engine bay to then be emptied and cleaned properly, and so spring clips might just be rather more helpful. So it's not just a cosmetic consideration.
:smiley:
« Reply #68 on: August 26, 2009, 11:07:33 pm »
The supplied clamps are standard jubilee clamps.
« Reply #69 on: August 26, 2009, 11:18:56 pm »
....Then it's gotta be worth £8 to be able to spring clip off the Khazi Can each time you need.
Offline QD MBE
  • -Receive: 102
« Reply #70 on: August 27, 2009, 09:11:08 am »
Steve,
can't see the pics, did the clips fit well, with correct tension to prevent leaks?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #71 on: August 27, 2009, 09:27:58 am »
Steve,
Yep them seam fine, I have done my normal commute to work (80miles) and there is no leaks  :happy2:
Offline candy turbo
« Reply #72 on: August 27, 2009, 09:36:56 pm »
i picked up 2 clips today , thats all they had ! just need the kit now ! :wink:
Offline keith
« Reply #73 on: August 27, 2009, 09:44:21 pm »
Does the can not unscrew from the head?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #74 on: August 27, 2009, 09:46:48 pm »
^^^ Not sure what you mean Keith  :confused:
To empty the can (when installed in the BSH standard location) you need to remove the two hoses connecting to it then it just pulls out of the bracket.
You can then open the tap on the bottom and drain it off to a suitable container  :happy2:
