Author Topic: It just died !  (Read 1866 times)
Offline Yetisimon
It just died !
« on: August 06, 2013, 08:47:55 pm »
Can any one help with this.
Just driving along and the car died! It's like someone just turned the engine off no instrument lights at all and the car will not crank  but all the windows headlights and radio works fine.
I've got a error code of 02403.
Any help would be appreciated as I am at lose as to what to do next
I suppose the model of car would help its a
07 edition 30 golf
Offline doylebros
Re: It just died !
« Reply #1 on: August 06, 2013, 09:03:14 pm »
Check the engine fuse box for corrosion on the fuse links!
Offline Yetisimon
Re: It just died !
« Reply #2 on: August 06, 2013, 09:13:50 pm »
Checked all the fuses I've got power in all the right places and to the starter.
If the instrument cluster is died would that stop the car from cranking ?
Offline doylebros
Re: It just died !
« Reply #3 on: August 06, 2013, 09:17:53 pm »
Most likely, immo built in to the cluster.
Offline doylebros
Re: It just died !
« Reply #4 on: August 06, 2013, 09:30:15 pm »
This guy had similar problem
http://www.seatcupra.net/forums/showthread.php?t=257393
Check a few of the suggestions offered may help.
Offline swedishfireball
Re: It just died !
« Reply #5 on: August 06, 2013, 09:48:08 pm »
Had exactly the same turned out to be ignition relay. Was relatively cheap so I hope yours turns out to be the same.
