Author Topic: Oil leak?  (Read 3431 times)
Bigbaxt
Oil leak?
« on: August 07, 2013, 07:23:13 pm »
Hi all
My MKv Golf GT Sport 170 has developed an oil leak around the front n/s of the engine, It looks as though it is coming from around the top of the housing where the screw top is, Is this a common thing? as i seem to be topping up with oil every other day and at 50 quid a tub its not funny no more.
I have done an oil change and changed the filter and seal, but still comes pissing out, would it be worth using a genuine filter and seal? and buying a new screw top from the dealers??
The car has done 50k and has had a stage 1 tune and been de dpf'd giving me 206bhp and 325 lb of torque.
cheerz
Offline Llew
  • -Given: 45
Re: Oil leak?
« Reply #1 on: August 08, 2013, 12:45:23 pm »
How much oil is it losing a week/ month
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline OSB
  • -Given: 32
Re: Oil leak?
« Reply #2 on: August 08, 2013, 01:22:43 pm »
When you changed the filter and seal are you sure that the old seal came out? Part of it left stuck in maybe?
Is the housing marked or damaged  where the seal fits?
Tightened to correct torque? Too much can be as bad as too little if the seal is distorted.
Bigbaxt
Re: Oil leak?
« Reply #3 on: August 08, 2013, 05:43:20 pm »
Losing at least a litre a week, if not more.
cap seems ok and was torqued up correctly, only started happening after last couple of oil changes, may just buy from vw as much as it hurts me, to save the hassle
Offline OSB
  • -Given: 32
Re: Oil leak?
« Reply #4 on: August 08, 2013, 07:39:11 pm »
VW OEM may be more expensive, but does tend to be made to good standard!
Offline Llew
  • -Given: 45
Re: Oil leak?
« Reply #5 on: August 09, 2013, 01:23:28 am »
Check that you have replaced the dipstick properly  I bet it's that it needs to be clipped in
Bigbaxt
Re: Oil leak?
« Reply #6 on: August 09, 2013, 10:15:11 am »
No its deff coming from the oil filter top, when the car is running i can see it coming out, Time to visit the stealers i think
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Oil leak?
« Reply #7 on: August 09, 2013, 08:34:00 pm »
Do you have any photos?
Bigbaxt
Re: Oil leak?
« Reply #8 on: August 10, 2013, 11:40:34 am »
can do, ill take some later
Bigbaxt
Re: Oil leak?
« Reply #9 on: July 08, 2014, 04:11:56 pm »
Sorted the oil leak. Went for an original vw oil filter and seal. Ditched the aftermarket Unipart filter and the leak has stopped.
