Author Topic: Upgrading Fuel Pump  (Read 10612 times)
Offline Janner_Sy
  • -Receive: 113
Re: Upgrading Fuel Pump
« Reply #30 on: August 24, 2009, 04:25:14 pm »
I paid online
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #31 on: August 24, 2009, 05:53:42 pm »
What's the maximum pressure that these after market fuel pumps can deliver?
Offline Janner_Sy
  • -Receive: 113
« Reply #32 on: August 24, 2009, 06:15:42 pm »
no idea mate, but its more than enough for what jonnyC is pushing out of his, so i doubt you'll max out these
« Reply #33 on: August 24, 2009, 06:21:36 pm »
I seem to remember that they are 140bar.
  • MUBster DUBster
« Reply #34 on: August 24, 2009, 07:46:15 pm »
The reason I ask is because somewhere I read that the OEM fuel pump dished out 130 bar.
Doesn't seem like much of an improvement to 140 for close to 800 bucks...
Offline gazbutS3
« Reply #35 on: August 24, 2009, 07:52:28 pm »
the oem pump will deliver that higher up the rev range, but not in the mid-range :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #36 on: August 24, 2009, 09:23:32 pm »
plus its more about flow than just pressure...
Red ED35 5dr DSG
BLOG | BUILD
  • MUBster DUBster
« Reply #37 on: August 24, 2009, 09:36:54 pm »
As my wife keeps reminding me...  :signLOL:
« Reply #38 on: August 24, 2009, 10:15:22 pm »
 :grin:  :grin:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #39 on: August 24, 2009, 11:04:11 pm »
Red ED35 5dr DSG
BLOG | BUILD
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #40 on: August 24, 2009, 11:33:46 pm »
As John quite rightly says the pump upgrade is to increase flow/quantity as opposed to pressure.  What this does though is enable a greater pressure to be maintained in the fuel rail in the mid rev range by maintaining a higher volume of fuel in the rail.
The OEM fuel rail has a pressure relief which IIRC is maxed at approximately 130Bar.
The issue arises because the pump is being driven directly from the cam which means it is directly related to engine speed.  At mid range engine speeds the OEM pump cannot flow enough fuel to feed a modified engine.
Stu...
