Author Topic: Help please - clutch  (Read 1028 times)
turbomook
« on: August 08, 2013, 08:50:49 am »
Hi all,
Please could someone give me some advice. I was out in the mk5 golf Gti last night. Put my foot down in second and the clutch peddle went straight to the floor and now I can not select any gears and the clutch peddle is stuck to the floor.
The clutch has never slipped and car had been running great.
Is this likely to be the clutch that has gone or something else?
Offline Llew
  • -Given: 45
Re: Help please - clutch
« Reply #1 on: August 08, 2013, 09:26:44 am »
 Could be the Master cylinder
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
« Reply #2 on: August 08, 2013, 09:32:30 am »
turbomook
« Reply #3 on: August 08, 2013, 10:51:57 am »
Thanks for the advice,
Going to get the tools out now and have a look  :happy2:
Offline gjseb16
« Reply #4 on: August 08, 2013, 11:20:12 am »
this happened to me on a mk4 golf and when I got down an had a look the clutch pedal had split allowing the master cylinder push rod to come through the peddle which caused the pedal to sit on the floor. can you get down there and pull pedal back up it was common problem on mk4 mate i took pedal off and had my mate weld it up
Offline sandancer
« Reply #5 on: August 08, 2013, 05:54:10 pm »
That's just happened to me a month or so back. More than likely the slave cylinder has failed. Feel around under the bell housing to see if there's any fluid there, gearbox out job to change it though.
turbomook
« Reply #6 on: August 09, 2013, 09:41:12 am »
Cheers for the info guys,
The slave cylinder has failed inside the gearbox, so car is now at the garage getting fixed.
