Author Topic: GFB DV+ OEM Diverter upgrade kit  (Read 110676 times)
Offline vRSAlex
  • -Receive: 253
Re: GFB DV+ OEM Diverter upgrade kit
« Reply #135 on: February 20, 2014, 10:53:34 am »
Its a D without the basket around it iirc.
Follow AKS tuning on Facebook
Offline robern2
« Reply #136 on: February 20, 2014, 02:09:29 pm »
Piston so the dealer says
Offline chris-182
« Reply #137 on: March 02, 2014, 02:27:37 pm »
Good write up, I'm new to vag ownership but will be getting one of these in the next month. :)
Offline AndrewJB
  • die gelbe Baron
« Reply #138 on: March 02, 2014, 02:44:19 pm »
If you read the whole thread you will see most people who bought them have since gotten rid
Offline chris-182
« Reply #139 on: March 02, 2014, 03:28:26 pm »
[quoteIf you read the whole thread you will see most people who bought them have since gotten rid
[/quote]
 without reading all 7 pages, why have people been removing them? and what is the best replacement?
Offline plex
  • Awesome Rabbit !
« Reply #140 on: May 02, 2014, 09:25:19 am »
This part is offline at awesomegti.
They said that there are some problems "yes customers experienced faults with the GFB DV+"
Offline parkysan
« Reply #141 on: May 07, 2014, 09:54:00 am »
Just thought I'd throw in my views of this product.
I had my car in the shop yesterday to replace a worn CV joint . When I say worn, I mean it was bone dry and needed to be cut out! Weird thing is the CV boot wasn't split so who knows where the grease went?  :scared:
Anyway, whilst it was in I asked them to fit a new Rev G DV as the car has done 97k and thought it was a good preventative measure as I was struggling to get 30 mpg on a 'sensible' run, although is still pulled really well when I drove it hard.
Turns out the car already had a GFB DV+ fitted, but after reading this post I asked them to swap it out anyway so that I could compare and I could easily drop the GFB back in if I needed to.
Anyway, even though it's only been a day here are my initial thoughts.
I took it on a 'sensible run' with the kids through A & B roads and clocked up 38 mpg average, way more than I was getting on a long-distance cruise! This is a huge difference  :happy2:
I know that better fuel economy isn't everyone's idea of an improvement, and let's be honest I wouldn't have a GTi if I was that bothered about it, but when you do quite a few miles it's nice to know you can get reasonable mpg when you want to. The car also seems to start slightly quicker, has smoother idle and even appears slightly quieter although this could all just be my perception.
The throttle response does seems a little slower, but not by much and when I floor it it seems to pull just as well up through the revs.
I know it's early days but all in all, I prefer the way the car drives with the Rev G fitted but will give it a few weeks of driving before I give my final verdict.
Hope this helps some of the guys who are undecided which DV to fit.
Offline DiZzYGT!
« Reply #142 on: May 18, 2014, 09:12:43 pm »
Fitted the revision G yesterday (06F 145 710G) and what a difference it makes! It's totally changed the way the car drives! Definitely recommend this part.
Offline plex
  • Awesome Rabbit !
« Reply #143 on: May 30, 2014, 09:41:28 am »
Rev G + DV+ ? right ?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #144 on: May 30, 2014, 09:51:14 am »
I think he means just the OEM Rev G, without ruining it with the DV+  :grin:
Offline xjay1337
  • -Receive: 377
« Reply #145 on: May 30, 2014, 10:33:00 am »
DV - you mean
Offline plex
  • Awesome Rabbit !
« Reply #146 on: May 30, 2014, 01:52:13 pm »
So everyone will remove this DV+ then and take OEM DV rev G ?
What about rev G issues ?
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #147 on: May 30, 2014, 02:10:38 pm »
I honestly don't understand that someone would fit a Revision G again, those here in Denmark that have chosen the GFB DV+ are more than happy running them. The cars reach the requested boost faster and have a more stable boost when having the DV+ fitted.
But ETTO IMO  :wink:
Over the top mod list ;o)
Offline plex
  • Awesome Rabbit !
« Reply #148 on: May 30, 2014, 03:05:42 pm »
Some people have issues :
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #149 on: May 30, 2014, 03:57:25 pm »
For the doubters - it's worth re-reading the thread. Trusted tuners on the forum have found it to leak boost (along with the Forge DV also).
OK, the OEM Rev G may still split after time, but you could replace every 2yrs if your worried anyway and treat it as a consumable.  :happy2: it is the best DV for drivability and holding boost
DV+ is an expensive attempt at solving a problem, which didn't work.
Hurdy is trying another possible fix, not sure how he has got on with it. . .
