Author Topic: GFB DV+ OEM Diverter upgrade kit  (Read 110675 times)
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
Re: GFB DV+ OEM Diverter upgrade kit
« Reply #165 on: September 28, 2014, 11:59:58 am »
Well engine mounts, eibach anti rolls, suspension bushes etc. S3 Brakes yes, but that comes with needing bigger wheels. fuel pump and then stage 2. By then i'll be nearing for a new car lol
Offline Spoonie
« Reply #166 on: October 05, 2014, 08:38:19 am »
Fitted the DV+ the other day. Comparing it to rev D, it feels that I gain boost earlier at lower rpm's. No data to prove this, just my feeling. Hopefully it will eliminate the turbo lag between fast gear changes.
Octavia vRS 2.0TFSI Stage 2
« Reply #167 on: October 25, 2014, 07:54:57 pm »
Ko3 or ko4?
Offline Spoonie
« Reply #168 on: October 26, 2014, 05:57:36 am »
max_75
« Reply #169 on: October 29, 2015, 08:47:08 am »
I bought 1 GFB DV+ for my Peugeot 3008 1.6 Turbo Petrol, I know VW and Peugeot stock diverter valve is identical. After install the "hiss" sounds become lesser but the build quality is definitely better than stock. I also wrote a step by step guide here here http://www.buddyjoy.com/blog/car-howto/installation-gfb-diverter-valve-peugeot-16-thp-engine with pictures and video.  :party: :party:
Offline DrChops
« Reply #170 on: October 29, 2015, 10:14:22 am »
Hi,
Had to post on the diverter valve.
Got a 05 GTI a couple of months ago (black, lots of optional extras) but within 500 miles had low oil pressure warning, two weeks in the garage, £500 for replacement oil pick up which was blocked with silicon from whoever replaced the balance cam a few months earlier!
Anyway, 3000 miles later and I'm thinking this car is a bit disappointing on the old acceleration front!  I know....sacrilege.  But, I've had MK1 GTI's, MK2 GTI 16 valver's, Corrado VR6 and I'm used to a good pull all the way to the redline, you know proper acceleration and this MK5 just wasn't impressive.
Well, I self diagnosed the diverter valve as the problem (through reading forums) and replaced it a few days ago with the GFB £102 part using the directions in this thread.
Yes Yes Yes!!!!!!!!!!!!!!!!!!!!!!!  Massive difference.  Big smile now.
The silicon diaphragm was shot and only hanging on by a thread.  Who knows how long this GTI has been under performing and how many others there are out there with a broken DV?????
It took me about an hour an a half.  Using the tools recommended in this post.  To be clear, I gained access for the 1/4 wrench by jacking drivers side (chocking well) removing the plastic trim, lying alongside the front of the car and reaching in with one hand.  Top tip is to tape your wrench to the extension and the extension to the 5mm hex.  This way you won't drop these bits during the job.  Most of the time was getting confident that I had access to the DV and the car wasn't going to crush my arm.  Swapping the GFB bits onto the OEM solenoid was easy as was refitting.
I guess I effectively was driving a 2.0 L 16V with no turbo.  Now I have the Turbo boost working to the redline!  Ready for a remap now ;-)
I've never remapped before but I did the Superchips Bluefin remap to 240 bhp last March..........Absolutely worth the money!!!!!!!!!!  It now feels like a GTI should.  If you can insure it, then go for it.
Offline rumblytripod
« Reply #171 on: November 16, 2015, 03:05:17 pm »
changed mine, took about the same time, easier if you were double jointed.
Have to say didnt like being under and up into the car, had in on axle stands but still, :scared:
Offline Pesky jones
« Reply #172 on: February 02, 2016, 12:08:49 pm »
Oh cool, ill just go ahead and click that link
Offline Beej
« Reply #173 on: February 02, 2016, 01:39:35 pm »
What are people's thoughts on the newer version? I fitted a rev g last year before going 2+ (ko3), but that been about a year now and I am planning on renewing it, don't think there is an issue, but just replacing as an annual measure along with can follower.
Thing is, my brother is running a stage 2 tsi and after only a few months, done in a rev g so he has fitted one of these and reckons there is a noticeable difference in sound and pickup.
Anyone else fitted a new version and has tested for boost leaks like the first version?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #174 on: February 02, 2016, 11:20:06 pm »
I've got a GFB valve sitting in the boot awaiting fitting :signLOL:
Offline shoaybmakda
  • -Receive: 54
« Reply #175 on: February 07, 2016, 08:13:21 am »
@r5gtt let me know if your selling it  :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #176 on: February 07, 2016, 12:02:42 pm »
@r5gtt let me know if your selling it  :signLOL: No worries  :happy2:
Offline GTiBlues
  • Mr Blues
    • Bookface
« Reply #177 on: February 22, 2016, 07:11:01 pm »
My Revised G has given up. So will be ordering my DV+ now  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #178 on: February 22, 2016, 07:53:43 pm »
@shoaybmakda  sorry mate cars staying so dv is also staying in the boot for now untill I get time to fit it.  :sad1:
Offline shoaybmakda
  • -Receive: 54
« Reply #179 on: February 22, 2016, 07:55:11 pm »
No worries - not in a rush so will keep an eye out for any others thanks for letting me know
