Author Topic: GFB DV+ OEM Diverter upgrade kit  (Read 111690 times)
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: GFB DV+ OEM Diverter upgrade kit
« Reply #195 on: June 03, 2016, 12:01:13 pm »
Niki put up a load of pictures on Facebook (TFSI Tuning) demonstrating the differences (will need to search on a PC to find it).
Obvious signs of a fake were the sticker on the box looking distinctly sh*t i.e. very basic and not having a barcode. The billet body of the fakes had 4 holes compared to the genuine which has 3 (perhaps the copy was based on an old design?). The brass piston on the fakes had a very poor finish compared to the genuine item too.
As for the old versions, I believe it had a different piston and plunger, and they may have been a different colour but not 100% sure.
To be honest I would just save up the cash for a new one from AMD
Offline raz469
« Reply #196 on: June 04, 2016, 02:07:07 pm »
Sutting to do with the colour of the piston I believe. R5 posted it couple weeks ago. In this or the other thread. I just made a call to amd
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #197 on: June 04, 2016, 02:11:49 pm »
That one is young enough to be the last revision, AFAIK.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #198 on: June 04, 2016, 03:20:57 pm »
Ive found someone who bought two from demon tweeks in march this year, he doesnt know if its the latest revision though, does anyone know how to tell if its the latest revision?
pesky pesky pesky always asking questions  :signLOL:
The revised version has a brass colour piston and stronger springs and the older version had a black piston. Also the picture you've posted has a date on it   :doh:
« Last Edit: June 04, 2016, 03:23:24 pm by r5gtt »
Offline Pesky jones
« Reply #199 on: June 04, 2016, 05:26:50 pm »
So its the revised version then? I thought thr newer revision had the black plunger?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #200 on: June 04, 2016, 06:08:07 pm »
If it was bought in March it should be the latest revision.
Don't confuse the plunger and the piston. Piston is brass and the plunger is black
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #201 on: June 04, 2016, 06:24:46 pm »
wrong thinking pesky  :slap: as Dansays
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #202 on: June 04, 2016, 08:36:25 pm »
Found the FB post:
Offline Bigjimknickers
  • -Given: 55
« Reply #203 on: July 12, 2016, 08:49:35 am »
So are these reccomended by R-Tech? They check the DV anyway so I imagine turning up with one (asking first) an getting it installed before a stage 1 re map should be ok?
MK5 Gti stock, not sure what DV is fitted. Isn't it a pita on the mk5 to check?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #204 on: July 12, 2016, 08:54:00 am »
It is a pain to check on a K03 GTI, but R-tech do this before all Stage 1 tuning as you say. If you turn up with one they'll probably fit it there and then if you ask them as it only takes seconds once the DV is out.
Niki has tested these and found there is no loss of performance compared with a G, but the valve response (throttle changes) is much improved. I would wholly recommend it on a K03 as a fit and forget item - I got fed up of changing Rev G's every few months
  • -Given: 55
« Reply #205 on: July 12, 2016, 09:27:45 am »
Cheers Dan, I'll be sure to buy one before my visit, I'll be getting it done soon, had my VW caddy mapped last year & is been a huge improvement.
Offline 22
« Reply #206 on: December 22, 2016, 10:02:04 am »
Finally installed a VWR intake to compliment stage 2. So far everything is great EXCEPT that ridiculous whine you get on boost.
I've done a bit of research and many have said that the DV+ removes the whine? Some have also said the Rev D or G also gets rid of the whine.
Can anyone confirm any of the above?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #207 on: December 22, 2016, 10:26:48 am »
I have a VWR intake and a DV+. What whine are your referring to? The sound of the DV releasing pressure when you take your foot off the gas pedal?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #208 on: December 22, 2016, 10:36:07 am »
The whine is a K03 thing....... It's a harmonic resonance caused by the intake - some cars do it, some don't. The DV+ will not make any difference, neither will changing to a Rev D or G. Don't forget the valve is fully closed on WOT when the whine is present.......
Adjusting the intake can help though. The first intake I made for my car whined terribly - horrid noise. I ended up chopping and changing pipe angles & lengths until I completely eradicated it
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #209 on: December 22, 2016, 10:57:49 am »
Thanks for the explanation @Dan_FR! :drinking:
