Author Topic: GFB DV+ OEM Diverter upgrade kit  (Read 110691 times)
Offline Mikeygtir
Re: GFB DV+ OEM Diverter upgrade kit
« Reply #75 on: August 30, 2013, 10:06:14 pm »
yeah would be interesting to see if that issue mike is having is related to the K04 issue..
I'm looking into buying this (just need to time it so it doesnt arrive before i get back from the rig so SWMBO finds out i've been spending yet more money on the car) but want to be nigh on positive its not going to make the car worse prior to going for its stage 1..
Lee M
« Reply #76 on: August 30, 2013, 11:26:03 pm »
Hi mike.
I've been told that there is a different springs being shipped with these for k04 tfsi motors, over the ones in our setup (early version).
Heard anything?
I'm going to give AMD a bell tomorrow to ask.
Offline AndrewJB
  • die gelbe Baron
« Reply #77 on: August 30, 2013, 11:36:50 pm »
its all documented above Lee
Lee M
« Reply #78 on: August 30, 2013, 11:50:34 pm »
Cheers mate. Not sure how I missed all the above!  It's this bl00dy new tapatalk!
I'm going to swap mine back to be on the safe side until all this is resolved.
Lee M
« Reply #79 on: August 31, 2013, 08:52:29 am »
Are all the oem DV electronic bits the same and only the valve part different? That's what I assume?
I have my original DV still and AMD used the rev D valve on the car to fit the gfb DV+ too.
My plan was to re assemble the rev D to normal and refit. Then use my old original DV to make the DV+ once I get the uprated spring.
I'm presuming this should work?
Lee
Offline jon-tfsi
  • -Receive: 27
« Reply #80 on: September 06, 2013, 08:52:46 am »
Copied from mkVI
Important updates to DV+ T9351
GFB Technical Bulletin
DV+ (part # T9351) leak issue
5th September, 2013
Since the DV+ was released, it became apparent that there were significantly more variables than our initial testing revealed. This is because we have a patent pending on this product, and we were limited in how many different cars we could use during development since you cannot disclose the product to the public until the patent has been lodged.
The Audi/VW community has made us aware of a leaking issue with some of our DV+ valves, for which we’ve now engineered a solution.
The leaking issue is the result of a number of contributing factors, however it can be generally said that the problem is most common on cars using the K04 turbo. This is because in most cases, cars equipped with the K04 turbo run higher boost.
What we found is that it is possible for the plunger inside the solenoid coil to be forced open by high boost pressure, which results in a drop in pressure behind the main piston, causing the valve to partially open.
Whilst our initial testing showed the plunger to be capable of holding in excess of 30psi, we’ve since found that variations in the factory spring and a slight difference in the diameter of the o-ring used on the front of the plunger leads to significant differences in the ability of the plunger to stay shut under load.
Initially, a stronger plunger return spring seemed like a good solution, but after testing as many solenoid coils as we could, it appeared that the electromagnetic strength of the coils varies significantly, especially when hot. Therefore some coils were not able to reliably open the valve when a stronger spring was used.
Our solution? We have made changes to both the spring and the plunger to ensure that it does not get pushed open under boost, and that it continues to open reliably when the solenoid is energised by the ECU.
The changes to the DV+ T9351 kit are detailed below:
We have manufactured a spring that holds the plunger down with more than twice the force of the original factory spring
To ensure the solenoid is able to reliably retract this harder spring, the plunger has been made slightly longer to shorten the stroke. This means the  electromagnetic retraction force of the coil on the plunger is significantly increased
The diameter of the silicone o-ring on the front of the plunger has been reduced so the area exposed to the boost pressure is smaller, which further increases its ability to resist being pushed open (smaller area means for a given pressure there is less force being applied)
All new T9351 DV+ kits come with the new plunger (which can be identified by its black colour as opposed to the silver finish of the original plunger) and spring.
For the earlier DV+ T9351 models, all that is required is to replace the existing plunger and OE plunger spring with the parts supplied in the GFB upgrade kit
« Last Edit: September 06, 2013, 03:09:51 pm by jon-tfsi »
GOLF R Mk7
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #81 on: September 06, 2013, 04:20:22 pm »
Nice to see they are active on an initial problem... :happy2:
Diesel Daily Hack.
Lee M
« Reply #82 on: September 12, 2013, 08:17:28 am »
It is mate. But no mention of FOC upgrade kit for those already with an earlier version.
Offline Neilgti
« Reply #83 on: September 12, 2013, 08:48:03 pm »
After fitting my DV+ and after the issues raised on here I decided to refit my original valve until the upgrade kit came out,
I emailed AMD today to see we're I stand etc and this is the response I got within 5 mins of emailing them  :smiley:
Hi Neil,
We received a new order of DV+'s yesterday and with them was some revised
parts for us to send out to any customers they may have the issue. If you
could please let me know your address and I shall have a kit sent out to
you.
Regards
Ben
AmD Tuning (Essex)Ltd.
Follow the AmD Tuning BTC
Now that's customer service  :happy2:
MK5 GTi
MK5 R32
MK6 Gti, all gone but not forgotten
Now loving the 7R
Offline RobboGTI
« Reply #84 on: September 13, 2013, 04:03:57 am »
Hi Neil,
you.
Regards
Ben
I'm going to get straight onto them myself then!
Offline Neilgti
« Reply #85 on: September 13, 2013, 07:08:11 pm »
Had an Email today to say that my upgrade kit is in the post and No mention of a payment required  :happy2:
MK5 GTi
MK5 R32
Now loving the 7R
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #86 on: September 14, 2013, 05:54:32 pm »
Contacted GFB direct and was pointed in the direction of Ben @ AMD and both couldn't have been more helpful.
Upgrade kit on the way and no charge.
Seems they've met this head on, excellent customer service  :congrats: :congrats:
Offline Neilgti
« Reply #87 on: September 18, 2013, 05:00:26 pm »
Got my upgrade kit through the post today    :smiley:
MK5 GTi
MK5 R32
Now loving the 7R
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=cbkr6lci8bdato61t6tehq771r&/topic,19740.0.html
« Reply #88 on: September 19, 2013, 12:36:34 am »
.... And???? :popcornsoda:
Offline Neilgti
« Reply #89 on: September 19, 2013, 07:38:25 am »
And..........Not had chance to fit it yet  :P
Gonna try n get it fitted today and report back, after I put the standard one back in it pulled like a train, the 1st version of the DV+ must of leaked like hell,
Will see if this new one is any better, made it slightly longer and with a stronger spring.
MK5 GTi
MK5 R32
Now loving the 7R
