Author Topic: AIRCON pressure sensor problems  (Read 1760 times)
larrand
« on: August 09, 2013, 05:55:45 pm »
Hello all,
Joined after owning a 55 plate 1.9tdi mk5 for 18 months figured it could come in useful!
Having troubles with my aircon - the trouble being it doesntt work. Recently had an airbag fault wiped and it came up the aircon pressure sensor isnt functioning. Upon inspection this was said to be rotten/corroded and needs replacing in order to return cool air (system is fully gassed). Is this something I can fix myself? - if so without draining and regassing as that seems to be the most expensive part?
Havnt tried locating the sensor yet myself - sorry if ive missed the info on here had a quick search but no results.
Thanks in advance
Offline torque777
Re: Re: AIRCON pressure sensor problems
« Reply #1 on: August 09, 2013, 06:08:59 pm »
Normally the pressure sensor can be removed whilst still full of refrigerant ..if I remember its between washer bottle and drivers head light ...but do check
sent using my own fingers
larrand
« Reply #2 on: August 09, 2013, 06:33:22 pm »
Thankyou torque believe I have located from that, assistance needed before i go all d.i.y on replacing
