Author Topic: Is this Stereo Legit or Rubbish?  (Read 871 times)
Offline nelmser
« on: August 09, 2013, 08:53:46 pm »
http://www.ebay.co.uk/itm/261217906960?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Is this a proper VW stereo?  Seems quite cheap....
Also,  I currently have a RCD300, is this a simply switch, can I just remove the old, plug in this and hey presto, works fine?
2006 MK5 GTI 2.0
  • -Receive: 427
Re: Is this Stereo Legit or Rubbish?
« Reply #1 on: August 09, 2013, 09:00:55 pm »
I'd hold out for a RCD510 or RCD510 DAB on here in the For Sale section. That usually go for around the £200 mark on here so so difference in price. That unit doesn't seem to have a phone button, not sure ifBluetooth can be added, someone will be along to correct me if wrong.
Depending on the year of your car, you might need a new gateway otherwise you might get battery drain. I think if your car is 07/57 onwards your fine but best to check with someone who knows.
You'll need a FAKRA antenna adaptor (on eBay for around £10) and some coding IIRC but that's it.
looks like this....
« Last Edit: August 09, 2013, 09:06:18 pm by MC71 »
Offline nelmser
« Reply #2 on: August 09, 2013, 09:08:16 pm »
I don't understand all this jargon!  What is a gateway?
2006 MK5 GTI 2.0
Offline torque777
Re: Re: Is this Stereo Legit or Rubbish?
« Reply #3 on: August 09, 2013, 09:22:35 pm »
If your car is earlier than 2008 then you will probably need a change of can gateway or you will get battery drain issues ..mine is a 57 plate with a 08 chassis build so I had no issue ...the chinese version as your link shows are ok but have different spec ..no rds so constant radio tunning needed
This shows the different rear inputs on asian versions
sent using my own fingers
