Author Topic: changing new cam follower  (Read 3400 times)
Offline Janner_Sy
  • -Receive: 113
« on: August 24, 2009, 01:43:06 pm »
anybody know of a how to on changing the cam follower. i have the new follower already so may as well change it when i do the fuel pump
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: changing new cam follower
« Reply #1 on: August 24, 2009, 02:27:53 pm »
If it doesnt come out when you take the pump out. Just put your little finger into the hole the pump fits into and pull it out.
Very very easy to do an once you have the pump off it will take literally 5 seconds to swap
Carl :happy2:
« Reply #2 on: August 24, 2009, 02:50:15 pm »
Carl :happy2:
Make sure you bleed the excess fuel from the pump via the Schrader valve before you start and dismantling!
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: August 24, 2009, 03:06:07 pm »
which valve is the schrader valve?
Offline gazbutS3
« Reply #4 on: August 24, 2009, 03:07:03 pm »
and as Stu pointed out if you haven't disconnected the battery, don't open the drivers door as this primes the fuel system and you'll get wet :wink:
« Last Edit: August 24, 2009, 03:20:04 pm by gazbutS3 »
Offline gazbutS3
« Reply #5 on: August 24, 2009, 03:08:28 pm »
Its on the fuel pump body should have a dust cap on it, it operates like tyre inflation valve, press the needle in the middle to release pressure, better put a rag or similar around it when doing it though :happy2:
« Last Edit: August 24, 2009, 03:19:55 pm by gazbutS3 »
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: August 24, 2009, 03:09:07 pm »
and as Stu pointed out if you haven't disconnected the battery, don't open the drivers door as this primes the fual system and you'll get wet :wink:
now thats good to know, lol.bet ten bucks i do that by accident, lol
Offline Janner_Sy
  • -Receive: 113
« Reply #7 on: August 24, 2009, 03:10:24 pm »
Its on the fuel pump body should have a dust cap on it, it operates like tyre inflation valve, press the needle in the middle to release pressur, better put a rag or similar around it when doing it though :happy2:
yep seen it, just had a look. thankyou very much  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #8 on: August 24, 2009, 03:58:16 pm »
Just disconnect the Battery Sy
You wont get wet then  :smiley:
Carl :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #9 on: August 24, 2009, 04:24:35 pm »
i prob will TBH, nothing will need to be re-coded will it though
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #10 on: August 24, 2009, 04:26:36 pm »
You might get the steering wheel warning lamp on the dash, you're not using REVO code so that should be ok.
Stu...
