Author Topic: help please  (Read 1040 times)
Offline shayd
help please
« on: August 11, 2013, 05:46:14 pm »
hi ya guys wondering if anyone can help or if i even have  a issue or not i fitted a rns 510 but for some strange reason the unit when turned off you can still here the disc spinning for 5 min
then when you take the disc out you can still here the hard drive going and the fans coming off and on
i have a golf gti 58 plate
is this normal for the 510 or is there a fault any advice will be grateful
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: help please
« Reply #1 on: August 11, 2013, 09:18:58 pm »
is it an early A or B unit?
Cluster and Key coding
Location Great Yarmouth
Offline shayd
Re: help please
« Reply #2 on: August 11, 2013, 10:11:04 pm »
its a version b pal
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: help please
« Reply #3 on: August 11, 2013, 10:12:57 pm »
I've had 2 B units and it does that to mine too. I think it's normal .
Offline shayd
Re: help please
« Reply #4 on: August 11, 2013, 10:26:01 pm »
its just a bit weird why it stays on while its off u can keep hearing the hard drive spinning or if you have a cd in you hear that spinning for a while surley it should switch off or in the end surly it will drain the battery ???
Offline Matto
  • -Receive: 116
Re: help please
« Reply #5 on: August 11, 2013, 10:57:41 pm »
I have a Rev H and it does the same. I worried at first that it was going to drain the battery but never had an issue. It does turn off after a few minutes.
Offline shayd
Re: help please
« Reply #6 on: August 13, 2013, 09:54:10 pm »
cheers guys for the replys just worried to be honest if it kills the battery as i dont really wanna take the risk as i need the car every morning ? :confused:
Offline sanj
  • -Given: 17
Re: help please
« Reply #7 on: August 14, 2013, 12:10:53 am »
Told you! :happy2:
