Author Topic: Which anti roll bar kit?????  (Read 4128 times)
Offline Beddie
  • -Receive: 76
Re: Which anti roll bar kit?????
« Reply #15 on: August 19, 2013, 06:25:56 pm »
Another vote for H&R here, albeit in 26/22mm fitment  :happy2:
Carbon Grey Edition 35 - Here
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #16 on: August 19, 2013, 11:41:17 pm »
I've got Autotech and I would struggle to recommend then. I had a WALK fitted at the same time so unable to comment on isolated handling improvements, but they squeak over bumps and it annoys me.
Apparently the earlier batch also had problems with the brackets snapping, tho my later one does not seem to have this problem.
PLANS: Stage 2+
Offline xjay1337
  • -Receive: 377
« Reply #17 on: August 20, 2013, 12:03:29 am »
I completely go against H&R and say Whiteline.
Not sure how the whiteline ARBs can rust as they are powdercoated and if you grease the bushes fine they make no noises at all. I didn't notice any.  :party:
They are the best bars and get forgotten about because they're the underdog brand name and "only 24mm" but there's more to ARBs than the width  :happy2: :happy2:
I got mine from DPM on my TDI and could not fault the bars or the service as per usual with Damian.
Only word of warning is those with JOM coilovers should not mix hard ARBs as you'll be snapping drop link brackets every 3-4 months .
Offline vRSAlex
  • -Receive: 253
« Reply #18 on: August 20, 2013, 08:06:11 am »
The powdercoat is poor.  That's how they rust.
Follow AKS tuning on Facebook
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #19 on: August 20, 2013, 08:42:17 am »
Which anti roll bar kit is best to buy
H&R and lovin it ;p
Honestly, we are likely to vote for the one we have...I myself haven't tried 5 or 6 different ones, but H&R was my own decision.
« Last Edit: August 20, 2013, 08:44:56 am by ROH ECHT »
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #20 on: August 20, 2013, 09:11:06 am »
H&R and lovin it ;p
I have Autotech front and rear and will recommend the H&R ones Ron  :wink:
Although the Autotech ones are very good arbs the bushings let it down as Alex says.
So one more for H&R  :happy2:
Over the top mod list ;o)
Offline Jimbo_h
« Reply #21 on: August 20, 2013, 11:03:48 am »
I've got whiteline front and rear and they do creak a bit, just need to keep them greased. They've not rusted (yet) and have had them for 1.5yrs. Did make a noticeable difference to the handling.
I'm not saying they're the best (they're the only after market ones I've tried) but they're good IMO
CW MkV GTI | DSG | Driver Motorsport tune | HPFP | SPM downpipe | Sach performance coilovers | Volant CAI | 18" Oz Ultraleggeras | SPM ARBs
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #22 on: August 20, 2013, 11:55:26 am »
H&R 28mm/24mm  :happy2:
Two years and have been flawless, great upgrade
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #23 on: August 20, 2013, 12:33:43 pm »
I think a definitive answer is hard to find.
I have H&R (26 front and 24 back) for more than 3 years and they are great. Before buying the ARBs I did some research and by reading other peoples reviews I found out that the H&R bars need no maintenance (no oiling required for the bushings) and that they were of great quality. Both things are true.
So, another vote for H&R!
Offline jamma
« Reply #24 on: August 20, 2013, 02:23:42 pm »
Here's a stupid question as I havent got these, what difference do they make to the handling ?
Offline fingerling
« Reply #25 on: August 27, 2013, 05:02:48 pm »
Good experience with whiteline
Offline xjay1337
  • -Receive: 377
« Reply #26 on: August 28, 2013, 12:48:39 am »
They are called Anti Roll bars and they do just that, reduce roll. But they do a lot more than that, they completely change the handling balance of your car, on an already decent chassis like the Mk5 it can all but eliminate understeer and if you so desire you can have a very tail happy little hatchback!
« Reply #27 on: August 28, 2013, 08:52:09 am »
Another for H&R. :happy2:
« Reply #28 on: August 28, 2013, 08:55:20 am »
I had Autotech on my ED30 and had three brackets snap. They changed the design to 33% thicker brackets after several complaints and all was well after. Funnily enough mine didn't creak and worked well, but I too would struggle to recommend them over H&R or Eibach's.
