Author Topic: VWR brakes  (Read 1884 times)
Offline oak_grun
VWR brakes
« on: August 13, 2013, 08:41:07 pm »
Hi, I've been offered a set of front VWR 6 pots calipers. Are the discs readily available for this setup? Any one know what they cost roughly?
Offline oak_grun
Re: VWR brakes
« Reply #1 on: August 14, 2013, 07:25:46 am »
Anyone? I believe the discs to be 360mm.  Is this set any better than the Porsche NQSBBK kit?
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
Re: VWR brakes
« Reply #2 on: August 14, 2013, 08:46:23 am »
speak to daveb, when I was looking into them the vwr caliper is very narrow so getting discs for them was costly
but that was on an older kit :happy2:
www.distinctdetailing.co.uk
Offline vRSAlex
  • -Receive: 253
Re: VWR brakes
« Reply #3 on: August 14, 2013, 11:34:58 pm »
Dave does a fully floating setup for these with ap discs. Loads better than the stock stuff that's supplied with them.
Follow AKS tuning on Facebook
Re: VWR brakes
« Reply #4 on: August 14, 2013, 11:53:41 pm »
Never had any problem with the stock discs and that's driven on some mad roads in Europe think I must have done 40k on em now maybe more
Offline oak_grun
Re: VWR brakes
« Reply #5 on: August 15, 2013, 07:21:58 pm »
Do they fit behind standard Pescera alloys on ED30's?
Offline oak_grun
Re: VWR brakes
« Reply #6 on: August 17, 2013, 10:05:10 am »
^^ anyone running these behind standard wheels?
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: VWR brakes
« Reply #7 on: August 17, 2013, 10:34:04 am »
Not possible, the stock ET51 won't allow for use of calipers with pistons on the outside of the disc, except Tarox calipers with 10 pots  :smiley:
« Last Edit: August 28, 2013, 01:34:09 pm by danishmkvgti »
Over the top mod list ;o)
Offline oak_grun
Re: VWR brakes
« Reply #8 on: August 17, 2013, 08:44:11 pm »
Not possible, the stock ET51 won't allow for use of calipers with pistons on the outside of the disc  :smiley:
Not even with spacers?
  • -Given: 243
  • -Receive: 154
Re: VWR brakes
« Reply #9 on: August 17, 2013, 10:46:47 pm »
You asked if they would fit with the stock wheels, stock isn't spacers. But yeah chuck 50mm spacers behind the stock wheels and you have room for the world behind the OEM wheels  :laugh:
I'm sorry but i find that question a bit contradicting, hence the rude answer  :happy2:
Offline oak_grun
Re: VWR brakes
« Reply #10 on: August 18, 2013, 12:34:42 pm »
No need really....simple question that was all.....
Back on topic the guy I am purchasing them off says he was running them with 10mm spacers? Anyone able to confirm they will fit with 10mm spacers before I part with my cash.
« Last Edit: August 18, 2013, 12:40:01 pm by oak_grun »
Offline wigit
  • -Given: 129
  • -Receive: 42
Re: VWR brakes
« Reply #11 on: August 19, 2013, 12:11:27 pm »
VWR brakes initially came with two bell sizes given the clearance issue
the later VWR kits have there own dedicated spacer in a range of sizes
maybe worth giving VWR a call
Offline Sie
Re: VWR brakes
« Reply #12 on: August 25, 2013, 07:59:31 pm »
I've got the caprio based ones with built in 15mm spacer and fit behind my monza II easy also the chap I brought them off had them behind pescera.
So I guess depends if you have bells with spacers or buy some spacer if you got normal ones.
Simon.
Fettled Laser Blue '05 GTi 5dr
