Author Topic: Help erratic idle  (Read 1152 times)
Offline Gazzgti
Help erratic idle
« on: August 14, 2013, 08:17:46 pm »
Any help appreciated. Seems to drive fine however when at stand still the revs rise and fall then the exhaust pops like when I change gear. It's a 07 gti dsg any help much appriciated
Saintsteve
Re: Help erratic idle
« Reply #1 on: August 14, 2013, 08:29:18 pm »
Blown PCV  :happy2:
Offline Gazzgti
« Reply #2 on: August 14, 2013, 08:36:15 pm »
Cheers. Any one know the rrp and part number. Is the bsh kit an good
Offline xjay1337
  • -Receive: 377
« Reply #3 on: August 14, 2013, 09:08:36 pm »
Could also be a vacuum leak. I had the same issue when I attempted to change my cam follower (I had 2 metal pipes so failed) - there's a vacuum pipe to the right of the HPFP but down a little which can easily break loose.
Check your PCV by having the engine running and taking the oil cap off to see if there's any noticable change. If it runs like a bag of crap but gets better when you put it back on it could be something else.
Offline Gazzgti
« Reply #4 on: August 15, 2013, 09:02:04 am »
The other strange thing is that it only happens after a drive when the car is up to temp.
Offline Leebo310
« Reply #5 on: August 15, 2013, 09:25:26 am »
Does the car stay at temp?
55 plate GTI DSG / Revo remap / Miltek cat back exhaust / Evolution Motorsport Induction Kit / Sony XAV 62-BT head unit/ LED Rear numberplate lights
Offline Gazzgti
« Reply #6 on: August 15, 2013, 09:31:46 am »
Yes
Offline Gazzgti
« Reply #7 on: August 15, 2013, 05:13:53 pm »
Also only happens in p and d mode.
