Author Topic: 2005 gti still not running. NOW FIXED!  (Read 1132 times)
Offline mk4gti-t
  • -Given: 61
« on: August 15, 2013, 09:50:29 pm »
Right folks here goes, the saga continues..........
After trying a second hand ecu which failed misserably due to not being able to adapt it to my immobiliser/cluster i am now being told that when my ecu failed it managed to corrupt some software in the cluster! Whether this is true or not i dont know. The solution maybe try and recover the software somehow or would i be able to buy this -
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=111141100212#ht_425wt_958
Would it be possible to swap the lot and hope it works? Is it that simple?
Help me!!!!!
Thanks...
PS -
My original ecu was 1K0 907 115 A and this is 1K0 907 115 F
My cluster is 1K6 920 960 D and this is 1K0 920 972D
« Last Edit: August 17, 2013, 10:46:01 pm by mk4gti-t »
Offline mk4gti-t
  • -Given: 61
Re: 2005 gti still not running. NOW FIXED!
« Reply #1 on: August 17, 2013, 10:49:09 pm »
Fitted the ecu, clocks and key i got from ebay today and car started first time  :happy2:
After a bit of coding and adaption i got everything set as i want it to be. The only issue ive got now is the fuel gauge on the clocksive fitted doesnt work, everything els if fine. Ive tried firing the output from vcds and it doesnt move?
Any ideas?
