Author Topic: 2.0 TDI (BKD Engine) Cold start problem...Getting frustrated now!  (Read 43495 times)
Offline doylebros
Re: 2.0 TDI (BKD Engine) Cold start problem...Getting frustrated now!
« Reply #30 on: October 27, 2013, 11:34:47 am »
Your's is the easier of the two.
Remove the T25 bolts - "don't disconnect any pipes" - separate from the filter (to allow seal change)!
Notice how much fuel is in the housing (this is what empties) if that housing your fitting the seal too has a defective valve!
When refitting tighten each bolt evenly a "bit at a time and opposite position".
If the filter is black you have a problem with oil passing on the tandem pump.
Offline andybon
« Reply #31 on: October 27, 2013, 12:15:12 pm »
Just checked the fuel filter and this was how much fuel was in when i opened it up.
And this was the colour of the filter, Only a few months old. Seemed to have oil in it when i ran my finger in it
How hard can it be?
Offline doylebros
« Reply #32 on: October 27, 2013, 12:42:49 pm »
Level should of been above the filter by 15 mm ish when put in the housing.
How many miles since the change not time is the issue?
Offline andybon
« Reply #33 on: October 27, 2013, 03:41:57 pm »
The pic showing the level was took just as I lifted the lid off.
Probably looking at around 1500 miles since it was last changed.
How hard can it be?
Offline Trekmeister
  • Golf GT 140
« Reply #34 on: October 27, 2013, 04:01:59 pm »
Which valve could be defective?
Offline apples12
« Reply #35 on: October 27, 2013, 05:29:15 pm »
Injector seals...
The blackening of the fuel filter is gases blowing back into the fuel and clogging the filter.
Had same problem on my 1.9pd
Once the injectors were replaced after cleaning, new seals and torqued down, its been flawless for the last 35k
Injector specialist told me it was bad fuel,apparently supermarket fuel is good for causing this.
MK6 GT TDI  - CW - LUX pack
GONE
Offline Paul_zx6r
« Reply #36 on: October 27, 2013, 05:30:10 pm »
I had a similar problem,  I had a dti test done basically my injectors set up and they were way it, it helped a lot but its still a bit lumpy on start up
Offline doylebros
« Reply #37 on: October 27, 2013, 05:31:06 pm »
Your photos show:-
The level you would expect if everything is working correctly so if the vehicle hasn't been started there's nothing wrong with the housing and valves!
However, the picture of the filter shows a rather black filter for so few miles!
This black indicates the oil seal behind the tandem pump is failing which contaminates the fuel lift pump in the tank - next stage is to confirm the condition of the pump in the tank by removing the rear seat to access the pump.
Just read Apples12 post and as he says, that is common but google both for further comments.
But as I originally said the fuel housing was my problem!
« Last Edit: October 27, 2013, 05:37:09 pm by doylebros »
Offline doylebros
« Reply #38 on: October 27, 2013, 05:38:48 pm »
The fuel filter head the part with the pipework attached as show in the photos!
Offline andybon
« Reply #39 on: October 27, 2013, 07:14:52 pm »
So the next place to look is the fuel pump in the tank and check for oil there too?
I take it the seal in question is the one between the actual pump and the engine block, if so are these cheap to buy/easyish to replace by myself or is it a case of going tho a garage/dealer to get it done?
How hard can it be?
Offline doylebros
« Reply #40 on: October 27, 2013, 07:23:41 pm »
Yes, if that was the filter housing level from cold (as per the photo)!
However, that wouldn't normally just give one fault, if the tank pump is contaminated, you would get other symptoms - poor idle, light misfire etc.
Air in the system or lazy pump would and does give your fault, but it's more like a brown sludge on the filter than just blackening of the filter.
Offline andybon
« Reply #41 on: October 27, 2013, 07:46:19 pm »
That level was after been sat for 3 hours from last been tried (started then stopped when it started correctly)
So it's possibly a new pump that's needed?
Really am loosing faith with the car, been tempted to just trade it in all day and be done with it :(
How hard can it be?
Offline doylebros
« Reply #42 on: October 27, 2013, 07:57:51 pm »
It's not easy when you lose faith in your motor but more testes are needed before parting with any money!
Tomorrow, before starting cycle the ignition key three times to position 2 counting to five then on the four go start the vehicle and see if that improves it - (it gives the tank pump more time and chances to purge air if that's the issue)!
So until tomorrow! :happy2:
« Last Edit: October 27, 2013, 08:06:24 pm by doylebros »
Offline andybon
« Reply #43 on: October 27, 2013, 08:08:15 pm »
I will give that a go then go from there! Hopefully I will get to the bottom of it somehow!
How hard can it be?
Offline doylebros
« Reply #44 on: October 27, 2013, 08:28:01 pm »
When you changed the seal today was there any water droplets or muck in the bottom of the filter housing?
Also when you had the timing checked with VCDS did they do a full scan or have you got access to VCDS Tool?
