Author Topic: Rcd510 sound question ?  (Read 1018 times)
Offline hoggj
  • -Given: 17
  • want to no more ??
« on: August 22, 2013, 02:38:24 pm »
I have a rcd510 (changed my rcd300) and I can't find the booklet I got with the stereo, I have no sound in the back of the car now ?? But I can't find a fade switch on the unit? to make the music go from the front speakers and back speakers! Does this stereo not have a fade switch ?  :confused:
Re: Rcd510 sound question ?
« Reply #1 on: August 22, 2013, 02:48:28 pm »
I think the solution is to do wi the coding
Read a similar thread the other day
Depends what sound pack the new stereo was coupled to in the last car. Just needs re coding to tell it how many speakers etc you have in the current car
Offline hoggj
  • -Given: 17
« Reply #2 on: August 22, 2013, 02:59:13 pm »
Will that be an easy job for my local VW dealer to do ? Or am I better looking for an independent in Edinburgh ?
« Reply #3 on: August 22, 2013, 03:29:09 pm »
Check the vcds register on here. It lists all the people that own the vcds cable and software that allows diagnostics and coding.  Someone local to you could change the coding for a couple of beer tokens.
« Reply #4 on: August 22, 2013, 03:30:24 pm »
Found here;
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Will be far cheaper than going to the dealer!
Hope that helps,
Mike
