Author Topic: coolant leak but dont know where water is leaking :(  (Read 7981 times)
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #15 on: August 25, 2013, 05:40:42 pm »
I'm doing egr valve & cooler removal tomorrow so will put a guide together although its not too difficult to do anyways.
Jas
VCDS (Preston, Lancashire)
Re: coolant leak but dont know where water is leaking :(
« Reply #16 on: August 25, 2013, 08:09:25 pm »
Jas
Just read your build thread on tdi sport..Excellent mods you have donee.Look forward to the egr cooler removal as thats the next step am doing
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Re: coolant leak but dont know where water is leaking :(
« Reply #17 on: August 25, 2013, 10:28:23 pm »
Cheers ;-)
Offline sootpig
Re:
« Reply #18 on: August 25, 2013, 10:31:10 pm »
Jas
:happy2: :popcornsoda:  looking forward to this
Offline Tomm
« Reply #19 on: August 26, 2013, 01:28:21 am »
if your removing the cooler then you may as well remove the egr as well
i was told to take the egr cooler off and leave the valve. To see if its the egr it self. Do you think i would need to do anything else ?
« Reply #20 on: August 26, 2013, 01:42:00 am »
could leave the egr on as that way your not spending money on some thing that isn't causing it to leak
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #21 on: August 26, 2013, 10:48:04 am »
Egr cooler removal is quite cheap. Approx £13 for the water coupling and about an hour to do it
Offline Tomm
« Reply #22 on: August 26, 2013, 01:22:53 pm »
cars going into the garage on tuesday. il keep use guys updated.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #23 on: August 27, 2013, 12:31:21 am »
Today I did egr delete but not cooler, will hopefully get to it this week. I'll get a guide together shortly.
Jas
Offline Tomm
Re:
« Reply #24 on: August 27, 2013, 01:32:58 am »
Jas
I would imagine you would need to map the egr out of the system. Is that expensive ? If my egr is bad I'm a better of just replacing it with a new one rather than deleting it?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #25 on: August 27, 2013, 03:55:37 pm »
You can physically remove the egr by installing a delete pipe. This causes the ECU light on the dash. That's what needs mapping out (on its own will cost around £70) plus £80 for the egr delete pipe. Still cheaper, and more reliable than a new egr valve.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #26 on: August 27, 2013, 03:56:08 pm »
PS. You can drive with the ECU light on as I am until you get it mapped out
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #27 on: August 31, 2013, 09:38:02 am »
I've done my egr removal. Will get a guide done this weekend.
Jas
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #28 on: August 31, 2013, 09:38:59 am »
How did you get on at the garage?
Offline Tomm
« Reply #29 on: September 02, 2013, 01:18:20 pm »
they have bypassed the egr. I dont know exactly what they have done but said they have connected a pipe. I am going to keep analysing the coolant level.
