Author Topic: RNS 510 Firmware  (Read 76743 times)
Offline 182_blue
  • -Receive: 54
Re: RNS 510 Firmware
« Reply #105 on: August 31, 2009, 01:48:32 pm »
Sorry only saw this late.
This firmware updates both A and B units.
As for the speed being in KM it's because you have modified maps showing speed cameras.
HTH
Carl :happy2:
how do we change it to MPH though ?, something on the map file ?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #106 on: August 31, 2009, 02:13:39 pm »
Without seeing what's been added for the speed cameras I'm not sure.
It must be something to do with the data that's being added for the Speed Cam POI.
Where is the data coming from. If it is coming from a non UK source i.e. A foreign map disc that could be why.
But as I said I would need to see what files have been added.
Carl :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #107 on: August 31, 2009, 02:21:57 pm »
The files that get updated on the V4 disc I have with speed camera's are the CDROM.TOC and some of the POI IDX and HTML files under the tpd\ntcWeu_eu_20081110\ENG folder.
I suspend the v4 disc I have is the source of the problem not the speed camera overlay  :confused:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #108 on: September 02, 2009, 08:35:11 pm »
I've had a few people asking me how to rig up the voice control for use with the new firmware in the RNS510.  I have a similar setup in my car, known as SDS, since I bought it and it works well.  This is how I've done it myself (and this one is for Hedge's little passion wagon) - perhaps a little more complicated than required but, as ever, entirely reversible come sale time.
Parts you'll need (assuming you have the 26xx firmware, OEM Bluetooth installed and MFSW) -
Female Microphone Plug x1  1J0 973 332
Male Microphone Plug x1      1J0 973 119
Repair Wire x1                     000 979 019 (for Plug 1J0 973 119)
Repair Wire x1                     000 979 132 (for Plug 1J0 973 332)
Repair Wire x2                     000 979 009 (for Plug 3B7 035 447 B)
2 - 3m of screened cable (minimum of 4 core), some heat shrink and soldering equipment.
Connections are as follows -
Plug 3B7 035 447 B
Pin 7 = Mic In +ve
Pin 1 = Mic In -ve
Pin 9 = Mic Out +ve
Pin 4 = Mic Out -ve
The idea is to remove the plug from the microphone in the headlining and plug in one end of this replacement lead which is then run down the door pillar, to the back of the head unit and connected to the Mic In connections in the existing green plug (3B7 035 447 B). From the Mic Out connections in the green plug and back up to the microphone but this time plugging in to the cable that runs to the Bluetooth Unit.   I've soldered the connections and used heat shrink to tidy it up a little.
Here is the head unit end complete (i'll post up the other end when the plugs arrive)
Some pics of the microphone end
« Last Edit: December 20, 2009, 10:50:52 am by vRStu »
Stu...
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #109 on: September 03, 2009, 04:22:41 pm »
Has anyone else had their battery drain since upgrading to 26xx? Mine was dead this morning (cost me £100 for a new one). Just trying to determine if the issue is with my can gateway, or if its an issue with the firmware.
#1493
Offline 182_blue
  • -Receive: 54
« Reply #110 on: September 03, 2009, 06:21:43 pm »
how old is your car ?
Offline CocoPops
    • Kennet Heath
« Reply #111 on: September 03, 2009, 06:24:21 pm »
I've not had any battery issues yet.
Although my phone doesn't work fully now since the upgrade  :chicken:
As per here:
http://vwnavi.com/forums/showthread.php?t=11381
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #112 on: September 03, 2009, 06:29:22 pm »
Been hearing a bit about this phone issue, have you given the coding a once over.  One of the guys on Brisky has said a Blackbury thingy doesn't work properly anymore but SE and iPhone are fine - Odd.
Stu...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #113 on: September 03, 2009, 08:41:31 pm »
^^^ Yep I get the same, Blackberry 8310 doesn't work on the RNS-510 screen anymore but the iPhone is spot on still :confused:
PS -  Cheers for the parts list of the voice control stuff Stu  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #114 on: September 03, 2009, 08:48:51 pm »
I would be surprised if a firmware update has suddenly caused the RNS to suddenly be live all the time.
You shouldn't have needed to buy a new battery just get a decent recharger or was it completely dead. I had mine go flat when the fan kept starting of it's own accord due to water ingredd and I just used a decent battery charger for about 18hrs and it was fine.
Make sure you haven't got water ingress into the electric box in the engine bay.
Other than that can't see why else the battery would have been flattened as the ecu would have killed the power to the RNS anyway after about 60 mins
Carl :happy2:
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #115 on: September 03, 2009, 08:54:41 pm »
Carl, thanks for the advice, but there are plenty of reports on VW Navi about earlier Can-bus controllers causing power drains when updating to RCD510 and RNS510 systems.  :sad1:
#1493
Offline 182_blue
  • -Receive: 54
« Reply #116 on: September 03, 2009, 09:02:17 pm »
^ think he said he would be surprised if a firmware update caused the battery fail, not the RNS install
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #117 on: September 03, 2009, 09:03:33 pm »
And also stated that he couldnt see why the power would have been flattened.
On VW Navi, people with similar symptoms (flat battery) had also reported just updating to 26xx too. But yet to find out if actually updating the can gateway fixed the issue.
#1493
Offline 182_blue
  • -Receive: 54
« Reply #118 on: September 03, 2009, 10:28:29 pm »
When you say plenty of people, how many actually have had a rns installed fir a while and have just updated and now have a drained battery ?
« Reply #119 on: September 03, 2009, 10:31:59 pm »
I updated a week ago and it has been as good as gold.  :confused:
