Author Topic: RNS 510 Firmware  (Read 76692 times)
Offline Aidy06
Re: RNS 510 Firmware
« Reply #165 on: September 14, 2009, 03:53:48 pm »
Remember DO NOT put the keys in the Ignition  :smiley:
Carl :happy2:
Ive done it pal  :jumpmove:
Still even got all my stuff on HDD, didn't delete a thing for some reason  :party:
Unit seems more responsive, colours have changed also. Speed limit display works fine, all good here. Thanks again Carl  :happy2:
« Reply #166 on: September 14, 2009, 06:13:10 pm »
Can I just say that when I did my update the speed display worked perfectly in mph
Offline mortygttdi
  • -Receive: 146
« Reply #167 on: September 14, 2009, 10:47:38 pm »
It does show okay unless you have the maps with speed cams,  if you just have normal V4 maps then it should be okay,  Ive just gone from V4 maps with cams to V5 maps normal and its fine now.
Darren
« Reply #168 on: September 15, 2009, 12:16:05 pm »
Ive got V4 maps with Speed Cameras as well though. is that unusual?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #169 on: September 15, 2009, 09:01:12 pm »
Yes it is  :confused:
You will have PM Shortly :wink:
Carl  :happy2:
Offline mortygttdi
  • -Receive: 146
« Reply #170 on: September 15, 2009, 09:08:07 pm »
Carl can you let me know if you sort it cos I like the speed cams but also like the speed limitation on screen
Darren
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #171 on: September 15, 2009, 10:18:56 pm »
Will do
Carl :happy2:
R32UK
« Reply #172 on: September 27, 2009, 10:28:05 am »
Once again a big thx darren(mortydttdi) for sorting out my RNS510 and mfsw issues!  :happy2:
Offline golfman
  • -Given: 17
« Reply #173 on: September 27, 2009, 11:02:51 am »
Guys i have a 2006 mk5 golf with a version but upgraded to b version software do you think i could do this upgrade without flattening my battery :scared: :scared: :scared:
Vag-com Hex+Can in scotland
I Hate Timewasters...
R32UK
« Reply #174 on: September 27, 2009, 11:31:16 am »
I did pal and mine works fine :wink:
Offline mortygttdi
  • -Receive: 146
« Reply #175 on: September 27, 2009, 09:22:39 pm »
Scott having seen your VCDS scan this morning and now knowing you have an early F can gateway you will more than likely have battery drain problems,
Ive just updated to the S version gateway and all fine now.
No probs R32UK any time bud
Darren :happy2:
Offline golfman
  • -Given: 17
« Reply #176 on: September 27, 2009, 09:40:44 pm »
Darren :happy2:
Cheers darren looks like i wont be doing that upgrade then :sad1:
how much did the s version cost and was it easy to do?
do you thing that with the highline clocks that we retro fitted that there is a way of successfully upgrading the convenience module :confused:
cheers pal
scott
Offline mortygttdi
  • -Receive: 146
« Reply #177 on: September 27, 2009, 10:25:16 pm »
Every thing is upgradable its just the costs involved :evilgrin: I had the 2660 F/W for about 3 weeks with no problems whatsoever but I never left my car for more than 12 hours at a time?
The S version from VW was £130 and no it wasn't easy although strange cos when I changed Ollie288 his was in front of the ash tray where has mine was in the most stupid place imaginable!!! right up behind the foot pedals I could only get 1 hand to it and that was a squeese.
Ive been searching for the right comfort module and im trying to look for one with AT/CC I think mine is AK once that is upgraded ill have full control over the highline with the conveinence menu.
Darren
Offline golfman
  • -Given: 17
« Reply #178 on: September 28, 2009, 07:47:32 pm »
Darren
Darren was it just a straight swap of the s version or did you have to code anything?
i would love to have all functions over the highline,let me know when you are attempting it and how you are getting on.
how are you getting on with your xenons?
cheers
    scott.
Offline mortygttdi
  • -Receive: 146
« Reply #179 on: September 28, 2009, 08:22:55 pm »
Hi Scott the gateway needed coding but its very easy you just tick all the equipment on your car,  you cannot go by the old gateway cos the new one is totally different on the long coding...Once I find a comfort module ill let you know.
Im awaiting a ballast for one of my xenons due to one not working other than that Ive got the adapter looms from kufatec.de and there was also a broken tab on the top of one of the lights so ive plastic welded that but you carnt see it cos its under the front carrier they should be in next week hopefully :party:
Darren
