Author Topic: RNS 510 Firmware  (Read 76680 times)
Offline pazz
Re: RNS 510 Firmware
« Reply #180 on: October 10, 2009, 10:55:18 pm »
Your more than Welcome mate.
Regards the firmware just Check the Seals and as long as they are intact you should be fine
Carl :happy2:
The seals on the unit?
I'm unsure on weather to update mine. Its a second hand "off the back of a lorry" version B unit. I also think I may have the old gateway (07 reg).
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #181 on: October 10, 2009, 10:58:35 pm »
The unit has a couple of security seals on it.
If it was factory fitted they will be intact or if it came froma legitimate source.
If it "fell' out of someone's dash board whilst they were asleep then it will have had the back opened up to Solder the EEPROM to reset the Security code. These units can't be updated as they brick when reaching 10% of the Can Gateway upgrade part of the Firmware flash.
Carl :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #182 on: October 10, 2009, 11:10:08 pm »
If you open the unit up you will quite clearly see the solder on the EEPROM
See here :
EEPROM Solder
The guy that took those bricked his unit when updating to 2664 firmware (Same as 2660 just Skoda is 2664) and when we did some investigating this is what we found.
Carl:thumbup:
Offline Rob GTI
« Reply #183 on: October 16, 2009, 09:46:43 pm »
Ok so just to check I;'ve got this right:
To update firmware:
I burn file to a cd, verify.
Insert cd into rns, (turn on 1st, keep keys out of ignition)
Wait
Job done???
Is the above right?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #184 on: October 16, 2009, 10:31:16 pm »
That's right, mate!  Updated my firmware without issue - was a doddle!
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #185 on: March 21, 2010, 05:45:18 pm »
Is there a link to an alternate host other than rapidshare chaps?  :ashamed:
Thanks  :smiley:
Pete
  • MUBster DUBster
« Reply #186 on: March 21, 2010, 06:41:38 pm »
Is there an upgrade firmware for 2880 or later?
Offline mortygttdi
  • -Receive: 146
« Reply #187 on: March 21, 2010, 06:43:40 pm »
The Latest which I have on mine is 2720 just a bug fix for 2680 and again abit more faster start up,
Darren
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #188 on: March 21, 2010, 07:22:15 pm »
So I installed my RNS510 by torch light on friday night  :stupid: And I have currently not had an issue with battery drain, the longest ive left my car is 19 hours, can I assume I dont have an issue or should I be keeping an eye on it still?
From what I read on mygti http://www.my-gti.com/1101 I shouldnt have an issue with drain if my firmware is lower than 2660, is this true?
I have the following RNS510 fw version and can gateway info from VCDS:
fw 0900
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056190129
   Coding: 7F3F0340070003
   Shop #: WSC 01279 785 00200
Can anyone help put my mind at rest?
cameluk
« Reply #189 on: March 24, 2010, 03:36:39 pm »
With a gateway of 1K0 907 530 F don't go above version 1100 of the firmware
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #190 on: March 24, 2010, 04:40:10 pm »
Thanks for the reply Camel, its been sat without starting the engine now since Sunday so feeling much happier, although good to know that you and darren both think I will be alright.  Will eventually replace the gateway once I have bluetooth and microphone installed, but for the moment going to get used to my 900 firmware as it has all the features 1100 states and I belive HW03 units dont get SDHC support with 1200.
Offline mortygttdi
  • -Receive: 146
« Reply #191 on: March 25, 2010, 11:45:40 pm »
mmmm :happy2: ive got HW02 and sdhc 8gb card works fine although you have to format the sd card every time you put somerhing new onto the rns? Otherwise it says sd card error??
But when i put this new rns in i put about 550 tracks on at once and it was fine.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #192 on: March 26, 2010, 09:16:07 am »
transferring 500 tracks in one go is the stuff of dreams!  :laugh:  Will have to pony up the cash for a new can gateway but will have to wait till next month at least  :sad1:
Offline mortygttdi
  • -Receive: 146
« Reply #193 on: March 26, 2010, 02:47:27 pm »
 :grin: :grin:
Darren :happy2:
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #194 on: March 26, 2010, 02:51:41 pm »
^ How longs it take to complete that copy process Darren?
It takes about 3 minutes for one 6mb mp3 on mine without the FW update :sad1:
Pete
