Author Topic: RNS 510 Firmware  (Read 76683 times)
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: RNS 510 Firmware
« Reply #195 on: March 26, 2010, 02:54:40 pm »
Thats a long time Pete, even with a 1gig card I could manage quicker than that, think about an album in 4-5 minutes (10-12 tracks) might be the read speed of your SD card as these can vary alot depending on the chips used, might be worth trying a different card if you have one?
Offline mortygttdi
  • -Receive: 146
« Reply #196 on: March 26, 2010, 02:58:56 pm »
On mine it took about 30 mins :confused: but I was actually listening to stuff on the HDD at the time while I was working on the car :happy2:
If you are coping put it on the radio so it takes the stress off the hdd and sd card.
Darren
« Last Edit: March 26, 2010, 03:00:32 pm by mortygttdi »
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #197 on: March 26, 2010, 05:23:57 pm »
^ Ahhhhhhh, sorry fella's I'm being a moron. It was from an mp3/data CD that the copy was being executed from  :stupid:
I haven't actually tried from an SD card yet, ignore me  :P
I will try from my USB stick via the MDI on way home though  :happy2:
Cheers both.
Pete
cameluk
« Reply #198 on: March 26, 2010, 09:35:40 pm »
Cheers both.
You can't copy from the MDI to the hard disk :wink:
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #199 on: March 27, 2010, 06:24:23 pm »
Cheers both.
Double fail then Camel  :sad1:
Cheers  :wink:
Pete
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #200 on: April 02, 2010, 05:25:59 pm »
Folks will it be ok to install the newer version of firmware marked as 2720 / 2722 / 2724 / 2726 / 2728?
Has anyone tried this, and is it an upgrade?
  • MUBster DUBster
« Reply #201 on: April 03, 2010, 07:19:43 pm »
Thought I'd take the gamble...
The update definitely makes the unit faster and more responsive than the 1200 or 2600 firmware counterparts.
Plus, the update retains all your previous music, settings, sat nav favourites, etc. Result!!!  :happy2:
P.S.  My unit took 40 mins to complete the update.
Offline mclovin
« Reply #202 on: April 03, 2010, 07:30:35 pm »
Yep, did mine the other week and can confirm that it is a lot faster than it was with the 2600 firmware, quick install and didn't delete any of my saved music etc. Slightly annoyed that this update still hasn't resolved the Skoda bluetooth issue though, works fine with my iPhone but not my Blackberry, just like it did with the 2600 firmware.
« Last Edit: April 03, 2010, 07:32:06 pm by mclovin »
  • MUBster DUBster
« Reply #203 on: April 03, 2010, 07:33:22 pm »
What's the Skoda bluetooth issue?
Offline mclovin
« Reply #204 on: April 03, 2010, 07:39:29 pm »
The Skoda UHV bluetooth 1Z0 035 729 B (1Z0035729B) has an issue with RNS 510 firmware 2600 and above, with some phones it no longer displays the phone book and/or the call details although signal strength etc are visible for some phones. However, the MFD functions as per normal with phone book and last calls listed correctly, so it's not the end of the world. My Blackberry 8310 worked fine with firmware 1200 and below but it only partially works with any firmware above this (ie 2600 and above). However my Iphone 3G works perfectly with any version of firmware. Apparently this is not a problem with the 1Z0 035 729 D (1Z0035729D) Skoda UHV bluetooth kit and I hear that Android 2.1 phones work fine with the update.
  • MUBster DUBster
« Reply #205 on: April 03, 2010, 07:43:23 pm »
Have you tried updating the firmware on the Kufatec kit?  What version do you have at the moment?
Offline mclovin
« Reply #206 on: April 03, 2010, 10:38:26 pm »
It's not a Kufatec kit, it's a Skoda unit that I got from vrStu. This is a known issue with the Skoda bluetooth version B units and 2600+ firmware on the RNS 510.
  • MUBster DUBster
« Reply #207 on: April 03, 2010, 10:40:37 pm »
Ahh right...I thought I was on to something - no worries.  Hope you get it sorted.
Offline mclovin
« Reply #208 on: April 03, 2010, 10:57:01 pm »
Cheers, shame it affects the BB as that is my work phone so it gets used much more than the iPhone (which works perfectly with this firmware).
  • MUBster DUBster
« Reply #209 on: April 04, 2010, 01:23:57 am »
Just realised the DVD playback hack is no longer working.  Has anyone got it to work with the new firmware 2720?
